Breitling bezel removal
Hi,  Can someone please tell me how to remove the bezel from this Breitling?  Which screws do I remove or do I prise off the bezel with a knife? I have seen Breitling in house service promotional video on another model and it looked like they removed some screws, I just wanted to make sure. Thanks, see photo
Normally bezels can be levered off, I use an old butter knife. However this is of a different design.
Found this vid looks like not all of the screws need to be removed but most. PS be careful don't loose any of the screws.
Clockboy thanks very much for that I didn't see that one when I did a search the other day.
So great news you only need to losen the screws that are on their own, not the writer screws and don't have to remove them totally.
