Rotor bearing replacement
Dlechkun
HI I am new to the site my name is Dave. I have a tissot watch that I have had for over 30 years. It has been serviced several times. The last time I sent it in I was told I was told parts are no longer available. I decided to work on it myself. The problem I have is the oscillator rotor bearing looks like a press fit no bearing nut has anyone ever seen this type of setup. Is the bearing replaceable? The rotor is a tissot part and the movement is 7750. Any help would be great. Thank you.
Hi Dave; It's a bit hard to see which exact model you have and where you are located; but a quick search on eBay a seller in Canada has a 2nd hand for a 7750 ....... ?
Perhaps a possibility ?
https://www.ebay.co.uk/itm/Tissot-Rotor-Oscillating-Weight-for-ETA-7750-Swiss-Made/202598217838?hash=item2f2bcb786e:g:YsEAAOSwQFhbY1IL:rk:1:pf:0
And, fleabay US has several listings for 7750 parts including an oscillating weight, complete with bearing.
https://www.ebay.com/itm/Tissot-Rotor-Oscillating-Weight-for-ETA-7750-Swiss-Made/202598217838?hash=item2f2bcb786e:g:YsEAAOSwQFhbY1IL:rk:1:pf:1&frcectupt=true
There are also 2 complete movements for sale in case you're interested in having a spare movement for your watch.
Cheers,
TD
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
