Different mainspring dimensions
Hello!
I have a ETA 900 movement with a broken mainspring that I am looking to repair. I was looking for a replacement and found this information:
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&ETA_900
With the dimensions: 1.55 x 9.0 x 0.10 x 290
Then when I went to order one on cousinsUK I searched for the movement and found out that they claimed this to be the right replacement:
https://www.cousinsuk.com/category/filter/eta-esa-movement-parts
With the dimensions: 1.55 x 9.0 x 0.105 x 280
Which one should i try to find? will they both the dimensions mentioned do the job? (p.s I do not have the possibility to measure the broken one precise enough)
Thankful for all answers, regards, Jakob Vinkås
Newbie here, but I'm wondering if the slight increase in thickness compensates for the slightly reduced length? Also, what is the "9.0" in this measurement? I'm guessing is has to do with how much is reverse-coiled?
EDIT -  Finally found that it looks like it's the intended barrel diameter. Is that correct?
Edited by qhartman
From what i know, it is the inside diameter of the barrel
14 minutes ago, oldhippy said:
1.55 x 9.0 x 0.105 x 280 Will be fine. It has very little differance.
Thank you for the answer, I will order the one from cousinsUK then.
/Jakob
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
    • Hi as an addition a pertaining to the assembly of a 6319B  which will be handy for those working on this caliber Polly's 6139 guide.pdf 6139A.pdf 6139B.pdf
    • Casio MDV106G-1AV Gold DURO200 I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable. Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them. Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀 The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
