Eta 2834-2 behaves weird
Gaus
Have you demagnetised the watch and all your tools you are using to repair it? Are you using the correct oil? Making sure, you use the right amount on the escarpment.  Never oil the pivots on the pallets. Make sure the hairspring is nice and clean.
Inadequate data.
Graph?                        Show top and side view close up video/ pix of the oscillator.
Staff end shake?    Check if HS fouls itself, sticky, unlevel or touches the wheel/ cock
  • 4 weeks later...
34 minutes ago, Gaus said:
See the picture. This is after cleaning and without motion/calenderwork. Dirty/sticky hs?
Is this dial down? We already know dial up was good.
You did not disclose the end shake.
I'm not sure it makes any difference what way it's positioned when the graph looks like this, the suspicion OldHippy had from the beginning seems to have been spot on since this looks like a typical dirty/magnetized hairspring.
Just a thought before doing anything else .. clean and demagnetize...
i have to say moving fast in vertical is not something you hear everyday. Sticking hairspring sound like obvious cause but i would suspect that if it was sticking you would have the same reading in the 12 down vertical position as well, assuming the hairspring is not out of shape. if it runs normal 12 down then closely inspect balance pivots, make sure they are not bent and the ends are domed and not faceted in any way. another good idea is to open case back place watch in the trouble position and use extreme magnification or slow motion feature with zoom on your phone if you have one, and check the coils of the spring, observe how they expand and contract, are the spaces between the coils even, or does one coil have a wider gap on one side than it does on the opposite side, if so then you hairspring may be out of shape. I also have to agree with Nuce that BW can be out of shape too.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
