Eta 2834-2 behaves weird
Gaus
Have you demagnetised the watch and all your tools you are using to repair it? Are you using the correct oil? Making sure, you use the right amount on the escarpment.  Never oil the pivots on the pallets. Make sure the hairspring is nice and clean.
Inadequate data.
Graph?                        Show top and side view close up video/ pix of the oscillator.
Staff end shake?    Check if HS fouls itself, sticky, unlevel or touches the wheel/ cock
  • 4 weeks later...
34 minutes ago, Gaus said:
See the picture. This is after cleaning and without motion/calenderwork. Dirty/sticky hs?
Is this dial down? We already know dial up was good.
You did not disclose the end shake.
I'm not sure it makes any difference what way it's positioned when the graph looks like this, the suspicion OldHippy had from the beginning seems to have been spot on since this looks like a typical dirty/magnetized hairspring.
Just a thought before doing anything else .. clean and demagnetize...
i have to say moving fast in vertical is not something you hear everyday. Sticking hairspring sound like obvious cause but i would suspect that if it was sticking you would have the same reading in the 12 down vertical position as well, assuming the hairspring is not out of shape. if it runs normal 12 down then closely inspect balance pivots, make sure they are not bent and the ends are domed and not faceted in any way. another good idea is to open case back place watch in the trouble position and use extreme magnification or slow motion feature with zoom on your phone if you have one, and check the coils of the spring, observe how they expand and contract, are the spaces between the coils even, or does one coil have a wider gap on one side than it does on the opposite side, if so then you hairspring may be out of shape. I also have to agree with Nuce that BW can be out of shape too.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
