HELP!!! Screwed up my 2892-A2
To All
Ok I purchase a clone 2892 took it apart and serviced it with good results. So I felt brave enough to work on my Cartier Pasha with a 2892-A2.. Apparently I I screwed up  Timegrapher all over the place ...I used it on several movements and always had better results than when I started..Of course they were always the cheap Chinese movements.
Here is what I am up against. I took it apart and examined but did not notice anything wrong From what I read it is most likely the escape wheel or the 4th wheel. But I am not sure if I am analyzing  this right.I enclosed pictures of what I am seeing ... Sometimes the movements can get even more extreme than the pictures I uploaded
Definitely an interesting waveform! Can you change from the current to the B graph? In the B graph mode will display 192 seconds which will make it easier to look for patterns if there are any. Then I'm a big fan of timing in different positions to see if the problem occurs in all the other positions?
Obvious and simple things to check when the rate varies like this (plus it’s a newer movement so seems less likely to have an eccentric wheel):
- magnetism
- sticky hairspring coil, or coil fouling part of the movement.
Hi John
Thanks for reply
This three shots are in B mode
Face down
Face up
Crown Right
Same type results
I am tearing it apart to examine a little closer I obviously missed something.
- magnetism
Hi Rodabod
Not magnetized and coil spring looks fine ..
Nucejoe
Only removed one at the time no way they got mixed up. I just finished tearing it down again and all jewels look good pivots look good Almost finished putting it back together. Lets see what happens
Well my tech knowledge isn’t good enough to help but I’m watching with interest and hope you manage to get it sorted.
Were in the same boat ...Still not working right can not figure what I am doing wrong ...The only variable is I used 9415 on pallets instead on 9010..could that b the problem?
I am leaning towards on of the drive train wheels is screwed up
What we need access to is a different timing machine? One thing that can cause timing fluctuations is change in amplitude because of issues with the gear train or basically fluctuations of power through the gear train. There timing machines that will run time plots for both the rate an amplitude which makes it really easy to see if you have a gear problem. This is where was hoping with the longer display we can possibly see a repeating pattern and figure out if there's a particular wheel that's the problem. This is one of the times where paper tape was nice because you to run on nice long piece of paper and look for things.
Then the balance jewel assembly? When you disassembled are you 100% sure that you put the Cap stones back correctly? One side is curved one side is flat it's really easy to sometimes flip them over. If you look at them like under a florescent light you can look at the reflection on the top and see if the reflection looks flat or whether it's curve the way it's supposed to be because the curved side goes out the flat side goes down.
When you have it on the timing machine leave it in one position and watch the amplitude see if it's going up and down and how far does it fluctuate up and down? Then if it does fluctuate see if the fluctuation occurs at a regular interval.
John
Yes I I rebuilt this watch three times now and same results I am sure I installed cap jewels correctly...
This watch is close to twenty years old but I rarely  wore it ...I did all ready order a new mainspring with barrel and arbor ...The price of getting mainspring alone was negligible.
  According to this article it sounds like it would be the fourth wheel ...Which is the seconds wheel right? I get my parts confused sometimes lol..
https://adjustingvintagewatches.com/rate-stability-wavy-traces/
John
Amp stayed about the same but very low. Look how wacky this chart is
I upload a picture of my 6498  just to show I can dial it in if it lets me.
Edited by adiorio110
If this was a pocket watch with a little secondhand then that wheel is the fourth wheel. Typically it would go around once per minute indicating the seconds but on a modern watch conceivably it could go at a different rate.
Gear trains are interesting in that they have power fluctuations. Modern watches the power fluctuations are less because they understand things and have nifty test equipment to make sure they're less versus older watches that existed before timing machines and nifty computer simulations. So gear train fluctuations typically don't show up on the timing machine which is usually averaging over time anyway which is the average out all the short-term fluctuations. The only time you might see something is if you're having a problem and when the amplitude is low problems can show up as everything gets magnified.
At work I get spoiled the witschi machine I have has a full automatic microphone I time everything in six positions. Occasionally on American pocket watches I will get suspicious and look at the numbers on the last page then I run the whole thing again. On the watches I'm suspicious of the numeric page the numbers are different. A lot of times even between dial-up and dial down which should be the same there's enough time between timing that the numbers are different. But a nice characteristic of a watch is it tends to average out things like this and it's not noticed usually.
Then there is a way to see gear train fluctuations if your timing machine has a time plot feature. The last time I did a firmware update on the machine at work I now have a nifty time plot feature. It's interesting in that it auto scales to whatever the input is so the graphical displays might look similar but you have to look at the numeric scale on the left-hand side to see what they mean.
So to understand the time plot feature I'm attaching images. You'll notice the Rolex appears to have a problem but timekeeping wise it still looks fine. The Hamilton hasn't been serviced in I have no idea when this is the way I got it when I purchased it and it also looks outstanding for timekeeping even with the fluctuations. Both the Rolex and Hamilton were time when fully wound up. Then the seven jewel laco timed at the end of 24 hours which is why the amplitude is low looks really bad.
My  Chinese wieshi is not quite a Witschi LOL ...
I do not have access to a better unit...Is there any one thing in particular you would concentrate on ?  ..I already ordered a mainspring and barrel . If I have to replace one part at the time that is what I will do. Could always use the extra parts for another project.
What pisses me off is that I worked on disassembling and assembling a several different pocket watch movement and watch movements plus several  Chinese knockoffs movements   including a clone 2892....They all went off pretty well ...This movement was from my Cartier Pasha I bought new about 20 years ago it keep pretty good time I just figured why not freshen it up ...and instead I screw it up . I 'll get it working again no matter what and chalk it up to a lesson learned
Like rodabod said simple things, like contaminated  HS or .......
So lets find the cause to fix it.
If it run 32 hrs on full manual wind, I see no reason to replace the original high quality MS with some after market which even the supplier dosn,t know who made.
I learned a golden rule from a wacthmaker, when it gets you tired, put the movement in clean container and come back when you have rested . :bbq:
Regards
Regards
Nucejoe
Thats good advice ...I have already put it aside twice...tried rebuilding it from scratch slowly going over every aspect...I am at a loss for any solutions ..my only recourse is to replace parts in drive train one by one till I come across the culprit ... no one really seems to sure exactly where the fault lies from the info I can supply with my limited experience and testing equipment. I had already ordered the mainspring prior to knowing about the problem as a backup in case I messed up greasing the barrel (which I did not attempt)  ..worst case I'll know where to look first I ever see a similar pattern.
I'll fully wind watch tonight and see how long it takes to wind down but I am pretty sure that is not the problem as it worked fine before the tear down.
When you say the watch worked fine before the tear down Did you put it on the timing machine? Then you purchase the watch 20 years ago when was the last time it was serviced?
I was rereading everything did you replace the mainspring or barrel complete?
John
Yes I put it on time machine ... I lost the hand written measurements I took don't remember exactly what readings were but they where consistent and not running all over the place Line was running relatively straight.
I did not replace mainspring or barrel ..Did not even service it. I had ordered a new one and still waiting for it to be delivered.  Just in case I screwed up servicing mainspring .. I just purchased mainspring winders so I did not have the ability to practice mainspring service ..so I left well enough alone.
John
Hope your next reading be satisfactory. Enough skilled folks here to gurantee excellent results.
More info may help. So if you will, check side and end shake on all arbors specially staff.
I suggest posting pix of the piece at different stages of strip down, someone may see what you have not noticed, video of runing parts, balance HS, fork pallets so on.
Regards
Regards
Will do ..Waiting for delivery of mainspring and barrel before I make another attempt. So at least we can rule that out...
Unless you are also seeing fluctuations in amplitude which correspond with the fluctuations in rate, then I would not initially suspect that it is an issue with power delivery (mainspring and barrel).
If you are noticing near-instantaneous changes in rate then I would suspect it is an issue with the oscillator.
Take out the balance and escapement and see how the wheels are freely turning.
Then put the pallets and see how they snap from one side to the other. Se how they interract with the escape wheel.
Check the pallets not to be loosened or anything...
Check the pallets back-end - the one that interracts with the balance impulse pin - it must look nice and polished.
Then check the impulse pin not to bee loosesened.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
