Hello Im New Please Help
Hello and thanks for having this awesome community... I just purchased a mighty mouse watch on ebay from 1985 perfect condition however I dont know how to change the battery out and local jewelers dont have any clues as well. Even google resulted in nothing so hoping you folks might help. thanks much in advance Its a bradley time piece
Looks like a one piece case to me. The button on the back removes the crown and stem. Then pry off the gold bezel on the front. Hopefully the crystal will come off with it and the movement will come out the front.
