broken mainspring
Hi *,
I have another issue with my travel watch, the end of the mainspring is broken. Can this be fixed or do I need to resource a new mainspring? Where can I read about mainsprings as how to identify their size to be able to buy a new one?
I am sorry I am completely new and I do not seem to able to find the info what I am looking for.
Best regards,
Lui
7 minutes ago, yankeedog said:
you can usually look them up according to the manufacturer and type of movement.
Can't, its a vintage travel watch. It says 8 days swiss made and there is some more writing on the dial I cant read, not even with magnifier, because the dial is discolored and old. Wanted to post another topic with the picture of it but it seems my sd card just died too. Movement only says swiss made. First watch causing me headache. Spent about ~2 hours just to put the pallet back. I was close to a nervous breakdown. Went to bed after 5 am daughter woke us up at 8. This is a difficult business to do. :)
25 minutes ago, yankeedog said:
Busted is busted. Can't be repaired and can't be trusted. Time to spring for a new spring.
Thought it would be easier to fix as it seems that the extra metal plate was added to the main spring originally. The main spring itself is ok, but the metal plate snapped in two.
You could in theory fix it, but I would measure the mainspring and see if you can buy a replacement.
They used to rivet the extra bit on, but now its usually spot welded, but in some older watches they just have a loose end mainspring hook, which you might be able to do for this spring if you can't find a replacement, but it would be tricky.
W.J. Gazeley's book Watch and clock making and repairing explains how to do this. (1950s book). I will take a photo and post it from the book shortly.
Hi is this a travel clock as the spring looks a bit coarse for a watch If so as Tmuir says they an be repaired, I personaly have used both the rivit and the loose end fittings and done right are quite sucessful but it means softening the spring end  either to bend it in the case of the loose end fitting  and also the rivit method  for drilling  but care must be taken not to crack or craze the spring
Umm... I just started to deal with timepieces. I guess its a travel clock. I personally had the impression they used a pocket watch.
On 2/16/2019 at 6:42 AM, luiazazrambo said:
Very interesting Timur, thank you for this. Why does it say that if you bend the mainspring back to form the loose piece solid that it is soft? Is it because it gets soft from the heating?
You must remove the section of the spring the will become the loose bit before you heat the mainspring as heating the mainspring to red will anneal the spring steal so it can bend, not break. If you do not remove the bit of the spring that will become the loose bit first it would also be heated and annealed and then under tension in the barrel when the watch is would up it could buckle and let the mainspring go which would most likely damage the watch
  not true.  I have received both watches and clocks with a "shortened  a main spring",   I have shortened them.  vin
   with your staking set.  you can "broach"   a hole,  in spring or annealed spring. vin
I had seen that mainsprings can be repaired when the end snaps off like that.  I have never done it. However, that mainspring looks pretty well "set", and may not be applying optimal power to the train. However, if there is still good resistance power to the MS, and you did repair the end, it may just become a 7 7/8 day watch. A new spring would be best, but the lesson learned in repairing such a spring would not go to waste.
With a mainspring gauge or digital calipers you should be able to get the dimensions of the size you need, i.e, thickness and width. You can stretch the spring out along the edge of a table or desk with a tape measures, or(?) to get the length. When you do this, wear eye protection, and be sure nothing is around that can be damaged if the spring takes flight on you. Good luck.
For me it is important to learn how to repair the main spring or even measure the mean spring as i am a beginner, it would be nice to fix the clock/watch on top of that as a reward of my efforts. (as far as I can see i am going to be in trouble with the hairspring too)
:Bravo:
Nice work.
10 to 15 mm over the length of that spring probably isn't going to have a huge impact. It will be interesting to find out how long it runs on a full wind. I expect it to be less than when it was manufactured, but in part that is going to be down to the aging of the spring as much as to the fact that it is now slightly shorter.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
