screw head snapped off
Hello *,
I was trying to service my first ever travel watch and during re-assembly I noticed that the head of one screw is missing. I have not removed this screw before it went for cleaning and I have no idea where the head is (not found in the cleaning liquid), not like it matters now. Is there any way to remove the remain of the screw?
Best regards,
Lui
15 minutes ago, rogart63 said:
If you remove every screw from the movement plate you can put it in alum . There is several threads about it on the forum.
Thank you. I tried to search first but i was not sure what the methods are. Never heard of alum but I am going to learn about it now.
Will you post a pic of the other side? You may find the other end of screw sticking out so you could grip it. You are going to strip down the movement anyway. Use of penetrating oil always helps unscrew the broken piece, sometimes by a needle or screwdriver, not to mention special removal tools.
Chemical disolution is the last resorts,  you need to know the plates metal type or alloy to avoid it's distruction by alum.
Regards
Regards
It was not sticking out, however I was able to gently push the edge of the remain with a small 0.6 mm screwdriver just by the fraction of a mm at the time. Took about 20 mins but managed to get it out. What a relief. :) Thanks for the comment.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
