Watchmakers Lathe Motor Pulley Slipping
JBerry
Hey folks,
I recently purchased an 8mm Star watchmakers Lathe and a cheap chinese YDK Sewing Machine Motor to power it from eBay.
Regardless of the tension I put on the 4mm belt, the belt slips over the motor pulley and fails to turn the headstock.
Can anyone think of an easy fix to this problem? or a suitable pulley for this motor and a 4mm belt (the shaft onto which the pulley fits is 6.35mm in diameter)
If only I had a functional lathe to turn the pulley ;)
Thanks in advance!
Keeping the motor between my legs and using the foot switch to turn it on and off, I turned the V a bit deeper with a graver. Still not a great deal of purchase, very little torque and a lot of slipping...
Anyone know where to source a more appropriate pulley?
When I was an apprentice antique restorer way back in the 60's and machines being used were made in the 40's we used to use Pine resin for slipping belts. It was left to dry and then crushed to a rough powder, worked a treat on leather belts, not sure how it would go on today's synthetic belts though.
Well.....since I was so bullish on you getting the Star, I'm feeling bad its not yet working.....I'll make you a pulley if you like.  One time offer, I am not going into pulley business lol.   You have to supply a good dimensioned drawing of exactly what you want and postage.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
