Beginner - mechanism questions
p2n
I found an old mechanism in the shed and decided to clean it up.
It's now clean(er) and it needs about 6 new bushings - I can't quite do that yet. Until then I want to reassemble and check it over.
I took a load of photos before disassembly but of course there is always one more I should have taken. This is it - the shaft the hammer sits on, is this the correct position relative to the leaf spring?
There was nothing on this pin when I found the mechanism - what should be there?
Finally there seems to be an excessive amount of movement in the spring barrel - not the shaft. So much so that the barrel fouls one of the wheels:
When done will post the full story...
(ps - again each file was 7MB and each failed to upload - error 200, but was ok when reduced in size)
Edited by p2n
typos
The movement is a British made Smiths Enfield 14 day striking movement, it is a copy of a German Baduf movement made after smiths purchased the entire production line from Germany and relocated it to England, the pin you have shown with nothing attached is correct nothing should be attached to it, the barrel touching the wheel points to excessive wear somewhere the barrel arbor holes on the barrel ends or on the movement plates themselves would cause the barrel to sit out of true. If that is all you have of the clock then you do have a fair bit missing and it would only ever be a runner by getting another donor movement of the same type, but it is useful to hang on to these part movements you never know when the parts will come in handy, I have one Winterhalder clock movement that has provided parts for four other Winterhalder clocks.
This is a similar but later version of the movement you have:
https://clockrepairs1969.wordpress.com/why-i-wont-be-servicing-your-clock-for-40-how-to-service-a-smiths-clock/
There is more to the clock - the images show it partially reassembled. In brief - we moved home last August and part of the agreement was we took on the new place 'as it' complete with junk. So while clearing the shad I found the remains of a clock. The case had long since surrengered to woodworm and damp. All that was left was the momement. No trace of the dial or hands. It was full of dust and 20 years worth of mouse dropping and nesting material. I've stripped it and cleaned it. I'm part was through re-assembling it. There is a lot of wear on most of the bushings but otherwise it seems like it should be repairable. This is the first clock I've done so I'm taking it slow. I can't make busings yet and can't afford the premade sets and tools - but I've got a mini-lathe.
More photos here
https://photos.app.goo.gl/deg3Q42VT1Rxpkyi6
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
