Question on watch band/strap sizing.
MrRoundel
Greetings, folks. I like wearing leather straps on most of my wrist watches, but many of them tend to spin around on my wrist. If I tighten them to the point of being uncomfortable, they mostly stay put. I have a small frame, so my wrist may be too small to work well with standard sized bands. And I have been wondering about whether the spinning watch syndrome could be eliminated by having a band with a smaller buckle side. In other words, I'm thinking the spin effect is exacerbated because the hole side is so much longer than the buckle side, and if the shorter bands being sold out there get shorter by merely shortening the hole end a bit. If so, the same problem might remain, despite the watch band being shorter overall.
So, are short straps shorter on both sides of the band, or just the hole side? Many thanks in advance. Cheers.
Or make your own strap tailored to your size.After all it only has to fit one wrist.I like nylon.In this part of America ,you sweat a lot an leather deteriorates quickly. I use  plastic clips to fasten the band.maybe the addition of the flat spot they provide will help you out
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
