Name That Tool
Lawren5
3 A and 3B are screw head slotting files.
5 A is a screw plate.
6 A is really self-explanatory it is for measuring watch crystals
4 A looks like some sort of puller, hand or cannon pinion
1 A Looks incomplete I think it is the main part of a watch main spring winder.
1A is a K&D adjustable mainspring winder. Missing the part that hold the spring.
5A is a screwplate. Either for finding out which screw you need or for making new screws. Or repairing screw threads with?
Edited by rogart63
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
