Lc130
Advice on winders please
Hi All
I've made reasonably good progress at learning this as a hobby thanks to lots of help from forum members.  I'm outright failing on mainsprings though.  My $28 Seiko 6119A MS replacement went airborne when I didn't push it into the barrel correctly.  I bought a new one for the seiko and others because I don't have a winder.  I've long given up trying to hand winding automatics.
I picked up an old winder set on ebay.  But, most of the hooks are broken off making it useless.  The Bergeon winders are priced for professionals.  What do most hobbyist use?
Any advice is welcome!
Charlie
Edited by Lc130
Share this post
Link to post
Hi Charlie   What I use are my hands and plenty of patience The latter being the watch word excuse pun. usually when new springs arrive they are held in a former and once the orientation is sorted out place the former over the barrel making sure the spring fits in the rim then work the spring into the barrel. To make it easier what i try to do is, on a flat surface press the former down a bit on the spring so you have an edge this edge is the bit you fit into the barrel prior to fitting and pressing it into place. If you remove springs by hand and intentd to re fit clean the spring in alchohol and relube. Best to use rubber or latex gloves to avoid sweaty fingers marking the spring. Probably not the correct way but it works. otherwise use a winder. there are several types as you have [probably found out.
Share this post
Link to post
59 minutes ago, Lc130 said:
How do you keep from permanently bending the bridle on an automatic??
You aren't the only one to ponder this.I recently destroyed a Seiko mainspring trying to get it back into the barrel.The bridle just did not want to go back.I would have had better luck trying to drag a dog into a haunted house.The advised hand wind method works great on unbridled mainsprings.But for a Seiko automatic you need a witch doctor.
Share this post
Link to post
You bring up a good point on buying used mainspring winders. I have a few different types that I use, but mostly I use my old K&F Robbin's Patent #125a winder. The big reason is that the three winding handles still have their hooks intact. Another, Watchcraft, I bought at an NAWCC Mart is missing the hook on the smaller handle/arbor. I, like you, didn't think to check it when I bought it. Consequently I've only used it once or twice, as invariably I need the smaller size.
Recently, my Robbin's style didn't have the right sized barrel for the V&C I'm working on, so I checked my other winders. Fortunately, was able to use the largest size of the Watchcraft Bracelet winders I have. Otherwise I may have been winding it in by hand as well.
Moral: When buying a used mainspring winder, closely inspect those hooks. Of course, an honest seller should let you know (if they know) of such material issues before you buy. Good luck.
Edited by MrRoundel
Share this post
Link to post
I feel all your pain, I've had trouble with these and I found out the hard way about checking for the hook on second hand winders. I'm expecting to see a tutorial pop up from  @jdrichard on how to knock one together soon :D (and although I'm joking I wouldn't be too surprised, there doesn't seem to be a lot that man can't manufacture!)
Share this post
Link to post
I feel all your pain, I've had trouble with these and I found out the hard way about checking for the hook on second hand winders. I'm expecting to see a tutorial pop up from  [mention=1704]jdrichard[/mention] on how to knock one together soon  (and although I'm joking I wouldn't be too surprised, there doesn't seem to be a lot that man can't manufacture!)
Very funny. I’ll prepare a video on how to replace the hooks on mainspring winders....if enough people want this.
Share this post
Link to post
I knew you wouldn’t let me down, haha! And although I *was* joking, yes please to the video. Didn’t know they could be replaced so will be interesting to me at least.
Share this post
Link to post
So I had a quick look and with a lathe and some blue steel rods at about 1mm, it is possible to replace the stud on a spring winder.85e5142ae382b642ed0b47e5bb852521.jpg79158d29bdf593ff20afa9fcaffb0ede.jpgeb8bfaf302ebf1fff91c543f9b89464f.jpg9915594c31365a8710e79e3ca1132aa0.jpg538f4a415f430edfad9d0492d598618a.jpg8fba0b906f6c6bbe8e8a3969d709178d.jpgbbb50afcd0564c7d2fee78a05f642890.jpgI think you just punch out the old one and then grave the small piece of 1mm blues steel down to size with i minor 3 deg taper, then tap it into the opening. Easy Peasy
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
    • I have this vintage Seiko digital LCD watch from around 1985. The "dial" seems to be very dirty and I'm wondering how I can go about cleaning it. It looks like its mostly dirt and grime. What can I use to clean it? I tried looking around for a NOS dial with no luck...
    • Another mistake.. bent the spring the wrong side... i had to cut it off and bend it again however it seems that I fixed the mainspring and the clock started to work. Yes it is shorter now by 10-15 mm but it works. I am really happy. VID_20190221_231500.mp4
    • You can replace acrylic crystals on a lot of vintage watches with just a clawed crystal lift tool. Nice and compact, cheap too. https://www.cousinsuk.com/product/round-glasses-superior
    • Your Seiko Watch is considered a very inexpensive watch by even Seiko standards. We recently had discussions on Seiko watches and timekeeping there is an exact procedures Seiko recommends for timing. Casually your numbers are super good for a watch of this grade. Then tech sheets are really handy because this watch is using what's known as the etachron system. This is why I quoted something above on a normal watch you can push on the spring to get things in alignment but with this system both the stud can be rotated and you can rotate the regulator pins. You're supposed to have a special tool but you can do with tweezers. That makes it considerably easier to get things in alignment it also makes it much easier for those not paying attention to get things out of alignment. Then this " smart phone regulator " Thing you're talking about does it tell you if your watches in beat or not?
    • Normally changing a battery is really simple so if somebody sells you A watch just needing A new battery because they were too lazy to do it, that is strange? Just think you put the battery in the watch is running it increases in value dramatically so maybe they weren't telling the truth? Then we need the model number of the movement telling us that it is a Tissot PRS516 Isn't super helpful because according to link below and it's more like a series of watches. So there should be a model number on the back side of the movement itself.  AndyHull Gave you some good starting answers. 101 make sure you have power to the watch. But there are some additional electrical checks once you verify that Then there is the mechanical aspects. Just because the watch looks clean doesn't mean by quartz watch standards that it's going to function. Mechanical watches have lots of power things aren't quite right they might not run right but they will usually run through all this things that aren't right. The quartz watches are really critical on how clean things are lubrication one speck of dust in the wrong place depending upon the watches enough to stop it almost. So their way less tolerance for mechanical Issues which you can't worry about it until you verify the electronics is working. https://www.tissotwatches.com/en-en/shop/all-our-watches/t-sport/tissot-prs-516.html
