Mainspring winders
You bring up a good point on buying used mainspring winders. I have a few different types that I use, but mostly I use my old K&F Robbin's Patent #125a winder. The big reason is that the three winding handles still have their hooks intact. Another, Watchcraft, I bought at an NAWCC Mart is missing the hook on the smaller handle/arbor. I, like you, didn't think to check it when I bought it. Consequently I've only used it once or twice, as invariably I need the smaller size.
Recently, my Robbin's style didn't have the right sized barrel for the V&C I'm working on, so I checked my other winders. Fortunately, was able to use the largest size of the Watchcraft Bracelet winders I have. Otherwise I may have been winding it in by hand as well.
Moral: When buying a used mainspring winder, closely inspect those hooks. Of course, an honest seller should let you know (if they know) of such material issues before you buy. Good luck.
Edited by MrRoundel
I feel all your pain, I've had trouble with these and I found out the hard way about checking for the hook on second hand winders. I'm expecting to see a tutorial pop up from  @jdrichard on how to knock one together soon :D (and although I'm joking I wouldn't be too surprised, there doesn't seem to be a lot that man can't manufacture!)
I feel all your pain, I've had trouble with these and I found out the hard way about checking for the hook on second hand winders. I'm expecting to see a tutorial pop up from  [mention=1704]jdrichard[/mention] on how to knock one together soon [emoji3] (and although I'm joking I wouldn't be too surprised, there doesn't seem to be a lot that man can't manufacture!)
Very funny. I’ll prepare a video on how to replace the hooks on mainspring winders....if enough people want this.
I knew you wouldn’t let me down, haha! And although I *was* joking, yes please to the video. Didn’t know they could be replaced so will be interesting to me at least.
So I had a quick look and with a lathe and some blue steel rods at about 1mm, it is possible to replace the stud on a spring winder.85e5142ae382b642ed0b47e5bb852521.jpg79158d29bdf593ff20afa9fcaffb0ede.jpgeb8bfaf302ebf1fff91c543f9b89464f.jpg9915594c31365a8710e79e3ca1132aa0.jpg538f4a415f430edfad9d0492d598618a.jpg8fba0b906f6c6bbe8e8a3969d709178d.jpgbbb50afcd0564c7d2fee78a05f642890.jpgI think you just punch out the old one and then grave the small piece of 1mm blues steel down to size with i minor 3 deg taper, then tap it into the opening. Easy Peasy
Hi Fireftr 45
I too am suffering  exactly the same frustration on a Seiko 7S26C movement. I split the barrel only to find the same sort of mess Mark shows in his video with the added non bonus of a broken spring end. I also bought a second hand set of winders only to find out that they were too worn to be useful. Buyer beware when you cannot examine first! I checked Cousins and sure enough no springs to be had here. I decided to take Old Hippys advice and order a barrel complete prt. no. 0201075. On Cousins web site it states Seiko Barrel complete Hattori part no. 201.083 available May 2nd 2019. I will order this and let you know if it fits the bill.
Hope this helps.
Note that in Japanese movements the springs often wind the opposite way to the 'standard' Swiss movements. You can see in Mark's video above it has a RH bend. Therefore the standard spring winders don't work - the nib faces the wrong way and won't grab the spring.
I'm working on a Citizen with a 10mm barrel, and had to use a 9mm winder bit to wind the spring the wrong way, then transfer the spring to the 10 mm bit to reverse it before putting in the barrel.
Unfortunately, the Bergeon is for ETA movements. The movement I have is from the USA. Thanks for trying!
Should do the job the same, far as I'm aware. Provided the dimensions are correct.
Sent from my Redmi 4X using Tapatalk
Bergeon used to offer their old standard winders, and then offered the "Nivaflex" series with recessed eccentric hooks which were a lot nicer to use and easier on the spring. From what I remember the arbor diameter didn't change (or change much) between the two. I only have a regular set in front of me but a number 8 has an outside diameter of 11.90mm and an arbor of 4. Seems about right for older springs. The next size up measures 13mm outside also with a 4mm arbor. The new Nivaflex winders (still available) from Bergeon should have similar arbor diameters. The ETA series will undoubtedly have proportionally smaller arbor diameters which would be a pain with older springs meant for larger arbored watches.
There's always older K&D and Marshall and various other makes of winders on Ebay which are well suited to older American watches and almost useless on more modern Swiss stuff.
This is one of the many areas I'm not experienced or knowledgeable enough. I was going by the inside diameter of the Mainspring Barrel that I measured with a digital caliper at 12.0 mm. I do not know what the wall thickness of the Barrel is at the moment. The wrist watch is a 1930's Ingersoll Mickey Mouse. The Mainspring is not replaceable with a new one, as everyone probably knows, so I've cleaned it and now I thought I would try to reshape it some, for lack of better terms, before greasing it. The connection to the Barrel Arbor looks like someone else tried to use pliers to get it connected, but did not succeed.
3 hours ago, vinn3 said:
its hard to damage a main spring.   very often the main spring is put in the barel with the thumbs!  watches, not with clocks.
I wish that were true in my case, but I've broken the hole (rectangular slot) on one of the mainsprings from cold-working it too much. I've been trying the thumb method with some success, but I thought maybe the winder would do a better job to naturally get it done right.
Well still no joy with Cousins on obtaining a barrel complete for a 7s26c Seiko. They now show availability 29th May.
Anyone know where I can get one from? Are the manufacturers trying to shut amateur horology down?
Really disappointing not being able to expedite a repair in a timely manner. I totally empathise with Fireftr45 I too am getting really frustrated.
I noticed that many ebayers are buying up watch tools and although they are not interested in using the tools they are interested in boosting the price. I was bidding on Platax tool after watching Marks vid as I have broken balance. The price went stupid £350 ish. Thing is no-one new if it was worn, had defects or would do the job. If there was another way or tool to replace balance staffs other than DK which are just as hard to obtain I for one would be interested.
Thanks to all.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
