Junghans ATO-MAT (~1960???) stopped working
mcc
Hi,
this is the "family kitchen clock": This clock is at least as old as I am.
It has a W-707 movement...an ATO-MAT, which is
kinda "pre quartz"-movement: A rotor like a BIG balance wheel is equipped with four magnets.
The first two magnets induce a voltage into a pair of coils, which in turn switches a current,
which flows through a second pair of coils, which then pulls the second pair of magnets. Since
the second pair sits a little further away on the circumference of the "balance wheel", that
wheel gets a kick, and the circle starts at the beginning again.
After 55 years of measuring the time, the ATO-MAT suddenly stops working. I checked the obvious things
like corroded battery contacts, loose cables, emtpy batteries etc but found nothing. Since this clock is there
since I am able to think I definitely want to repair it. And it would be my first clock/watch, which I try
to repair.
But before I unscrew anything...what is most likely the problem? Is there anything known
like "the typical ATO-MAT problem" or "any germanium transistor will die after 50 years" or something
like that?
I found some schematics of similiar ATO-MATs (not the W-707), which were not THAT complicated.
If it is the transistor it will be hard to find a germanium transistor these days I think...
Short description of the problem: Insert a battery, switch the starter (which is a little piece of metal, which
gives the "balance wheel" its first kick)...the "balance wheel" swings a little (looks not like it would be slowed down
by any abnormal friction or so) but the amplitude decreases rapidly until it stops.
Thanks a lot for any help in advance!
Cheers!
mcc
Hi     As a rule its usually the transistor not switching on the ATO there are equivilant tables to find an alternative NPN or PNP what ever type is installed in your clock have a look on google, just type in your transistor and get a list.  The transistor you find will have a different case type so may be require modding to fit....  good luck
Hi Mcc   Just googled ATO-MAT W-707 and pulled up a load of info on the 707. I have up loaded a tear down on the 707 also Think the tranny is a AC125 germainiun  PNP it will probably be an old style plastic case.   Just a thought check the driving coil for being o/c, dry joints etc.       enyoy
Hi,
Thanks a lot for all the infos! :)
I have googled before...and found quite an amount of "stuff". The problem with google and the interne is: Neither is a watchmaker or watch repair enthusiast. For example: I searched for informations about the 7S26C movement of my SEIKO 5 wrist watch. And found (for example) the following contraductionous (huuuu....this word looks horrible wrong...) informations: NEVER touch the movement with bare hands and a video in which exactly this has been done. NEVER touch _BOTH_ of the pins, which adjust/regulate the hairspring and another video, which says: that one regulates the length and the other one adjust the idle position of the balance wheel and both can be corrected of course. And the whole variations of "the right oil" to lubricate the movement. And....
You get the idea.
That's the reason for me to come to the place -- this forum -- , where the density as the chance to meet people, who DEFINETLY know, what they are talking about, and repeat the question here... :)
By the way: It seems the my W-707 runs (or better: does not run....hehehe) with a AC122. But I have to confirm this later....with a stronger light and a better lens ;) I will check the coils also...thanks for all the hints and infos!!!
My W-707 has a plastic gear.
Thank you all again! :) :) :)
Cheers!
mcc
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
