Jacot tool and pivot file burnisher question
I have been searching for a Jacot tool but I have found  many come without a Bow.
My question is, I can purchase a bow from Cousins but it suggests   "Tie a piece of cotton string form both ends". Is this correct just thinking of its strength etc.
Edited by clockboy
Here you are Mark, ten minutes work. This one is made with 1.6mm piano wire and I slipped a plastic sleeve over it. The ends were shaped cold with round nose pliers then trimmed. I used a very tough upholstery thread to string it and it works a treat. In my earlier post I suggested using 2mm piano wire, but 1.6mm works just fine.
I mentioned this before but I can't remember to whom, but you will usually find a good selection of quality Jacot tools on the eBay.de (German) website. Pickings can be a bit slim in the UK.
If you are a BHI member then the annual auction usually throws up some good stuff.
If buying through eBay make sure the seller takes close up photos of the lanterns as they are often the first bits to get damaged - a mate of mine got stung in the past this way.
I had the same problem. The tool is in excellent condition apart from that and luckily the seller refunded a large percentage of the cost.
I got burned on two seperate sets with worn and totally unusable lanterns.
Hi Mark,
It was me that you directed to look at ebay.de
And I did find a beautifully complete Steiner Jacot tool that was in near perfect condition for $300US! I remember finding the exact same set on the current manufacturers website for almost $3000.
My only problem was finding a seller that would ship to the US as not many would...
Hi Mark,
Awesome!
I got my Elma Cyclomat from germany and a nice JKA Feintaster.
A couple of good searches:
http://www.ebay.de/sch/i.html?_sacat=0&_nkw=uhrmacherdrehbank&_frs=1
http://www.ebay.de/sch/Drehmaschinen-baenke-/74498/i.html
http://www.ebay.de/sch/Uhrmacherwerkzeug-/63200/i.html?_nkw=lorch&_frs=1
And if you want a great measuring tool:
http://www.ebay.de/sch/i.html?_odkw=feintaster&_from=R40&_osacat=63200&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0&_nkw=feintaster&_sacat=281
I know some people attach motors, but to me you will lose the sensitive touch required. Even my lathe which is powered has a safety driver to be used locked in the headstock when using the jacot drum. If something goes wrong when it is motor driven it could be disasterous.
If it was simply for polishing I can understand a motor being used, but for burnishing (work hardening the surface) then think a bow would be the better way.
Just recieved my Jacot.
All good apart from the lantern on the smallest of pivots (1-12mm) is missing.have the opportunity to send back or get a partial refund.
Im assuming the smallest lantern will be required on balance staffs?
Edited by jnash
I agree with Geo. The reason I am looking to purchase a Jacot tool is to get more sensitivity which my lathe lacks. I have a foot pedal controller but things can still run away & out of control very quickly if not careful.
Agreed, for pivot polishing you have to feel what you are doing. A motor takes most of your control away.
However, when making a new staff I like to size the final pivot diameter on the Jacot tool and I have often wondered wether what it would turn out like using a motor driven Jacot like a Rollifit - check it out:
https://www.google.co.uk/search?q=rollifit&espv=2&biw=1815&bih=905&tbm=isch&tbo=u&source=univ&sa=X&ei=0J9kVPW2FI7varzCgoAD&ved=0CCMQsAQ
Personally I would send that back - it's next to useless.
Check this one out - I can't see the lanterns properly but there seems to be spares in the box.
http://www.ebay.de/itm/Tour-a-pivoter-Steiner-Jacot-tool-lathe-Zapfenrolliergerat-Rolliersthul-Rollifit-/151472992713?pt=FR_YO_Bijoux8horlogerie_HorlogesPendules&hash=item23447e71c9
Its being sent back as we speak, its come at a bad time as it seems my Cowells lathe is damaged. So the refund will go to the spindle being fixed now...
You have a great blog by the way. Some great info on there.
You can link it in our Blog section if you like - just click to Add a blog and choose to "Link external Blog"
Thanks, would love to spend more time on the hobby however work takes priority. I'll add the blog thanks
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • Thank you so much, Hector and CJ. I appreciate the tech sheet and the video. Gasp, I think I will make the attempt. What's the worst that can happen? I think there may be a new balance complete in my future, though.  I'll update the post and let you know the result. R, Frank
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.  Watch this video. It think it'll give you an idea of the task ahead. From your 1st photo, I think you have a etachron type stud. Let me see if I can find a video on how to remove it from the arm.
