Hello
Gram
Hello Everyone,
I'm new to watch repair or anything to do with watches, in fact I don't even own a watch!  I'm a part-time (trying to retire!) airline pilot shortly about to begin a short course in watch-making.  So this is just an introduction and a hello to all keen watch-people, hopefully we'll be able to share more as I gain some knowledge an expeience.
Kind regards,
Graham
I only just got back to watches after a year layoff, but am happy to be back trying to finesse these mechanical marvels back to good order. I'm sure that you'll feel quite welcome here. The resident experts and enthusiasts are quite forthcoming with sharing their knowledge, so it's a great place to hang out. Good luck on your future mechanical timekeepers. Oh, and quartz as well. Cheers.
Hi Gram,
Welcome to a very friendly forum where helpful knowledge abounds. I for one don't find it in the least unusual that you don't even own a watch. Time displays have become so ubiquitous that they're literally everywhere you look. Your cell phone will have one I bet. As long as your cell carrier is vigilant about keeping the link open to its time server, you can assume it's accurate as well.
Sit back, buckle up and prepare for knowledge to flow freely and without charge. My own interest in is quartz and kinetic movements but I assure you, many more on this site are fond of mechanical movements of all shape, size and complications.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
