Hello
Herbie
Hi everyone,
I live in the UK (N. Yorks) but am originally from California. I just got into horology very recently as several work colleagues are into watch collecting and I've always found great joy in taking things apart and putting them back together again. I bought a few job lots of movements from ebay to practice on and am really enjoying it. Mark's video's have really got me interested in taking this into a full fledged hobby or even further.
Cheers,
Herb
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
