One more to id...
Working on this unbranded movement that is causing me headaches.
I suspect that the h/s is not the original as the collet has been brutally squashed together to stay on the staff.
Runs fine with dial side down but misbehaves with low amplitude when flipped.
And the h/s stud has to be pushed high up to have the h/s reasonbly flat.
There are a couple of design features that to me are a bit unusual:
- The screws holding the cap jewel go in from the top of the balance cock. I usually see them (annoyingly) going in from the other side and efficiently preventing any inspection of the cap jewel without removing the balance from the cock.
- the ”pin” defining the setting/winding positions is here part of the setting lever spring rather than the setting lever, which I find much more common.
If anyone can hint on the make, I am very grateful!
This was a odd one, but looking at it I would say the trainbridge reminds me of an American Watch like Waltham Riverside Grade 371.
But the lack of markings makes it hard to know, but just as a push i would look at that direction.
Edited by HSL
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
