Mainsprings
rduckwor
You might get away with a pair (or two pairs) of round nosed pliers, with small "noses", something like this.
https://www.ebay.co.uk/itm/small-round-nose-BAIL-MAKING-jewellery-pliers-3-6mm-5-6mm-jaws-bsis-bl-sm/222883655206?hash=item33e4e6ae26:g:h2gAAOSwqu1aqlSw:rk:18:pf:0
Bending tempered steel is always a bit of a hit and miss affair, so I would be tempted to fit the spring in the barrel and see if you can catch the spring with the arbor and then press the arbor in to the hole, it may not need any bending at all.
