Clock for Beginners ?
HSL
Ok I have to confess I began to read up on clocks and follow the threads here and enjoying them very much. I have almost gone over to the dark side ;)
As usual when my interest have been triggered I will come with a bunch of strange questions.
1. Is there a clock movement type one should avoid as a beginner?. (cuckoo clocks are already out of the question for now!)
2. Which tools are essential to acquire, I guess most of my watch repair tools are a bit tiny for clocks?.
3. Is there any book clock makers considers as essential reading?.
Hi there on clocks to avoid for the beginner, three train westminsters, Cuckoo clocks arent too
bad if a bit fiddly. American Ansonia clocks are ok but mind the open springs and be careful. Most two train clocks are straight forward enough, Look out for worn bearings and duff pivots. If attempting a french clock be aware that the pivots are glass hard so great care is need when working on these.   Books, Any thing by Laurie Penman, Brian Loomes Mick Watters just google clock repair books the list is long...    Tools  Decent pliers, flat smooth jaw, fine smooth, standard engineering pliers,  small hammer, pin punches, center punch, again look in the books for recomendations. Donald De Carle ' book on clock repairing is quite comprehensive.  Its a differnt world to watches just gear up                all the best
Watchweasol has covered most of it already, but I will add avoid anniversary clocks if just starting out as despite looking simple they can be a real PITA, also avoid fusee clocks as the mainsprings are strong and without a mainspring winder you will never get the spring in or out of the barrel
Stay away from cheap travel clocks or Metamec clocks as they are cheaply made and can cause you extra problems whilst leaning
Got lot of it and orderd the rest. I even got me a Badishe Movement in a horrible state of course while I was on it.
The Donald De Carle book I bought for a starter was named "Practical Clock Repairing" hope it was what you ment, I have packed it down in my luggage since it will be my evening amusement while I am on a bussiness trip this week.
Thanks for the advice.
Okay done reading and got a practice movement the other day. It's obviously a German Badishe of some kind but seemed to be easy enough for a start.
Here are some pictures of it but unfortunately I got so excited tinkering with it I forgot to take more pictures.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
