Elliott 8 day platform escapement
nad
Currently working on what I believe to be an early 80’s Elliott 8 day clock that's in need of some attention.
While it was running when it came into my possession it was losing 20 minutes over 5 days so needed some attention. She's not had the easiest of lives and it showed. At some stage it looks like someone has taken a Dremel to it, I'm guessing to try and “Polish” things up but they only managed to grind parts such as the end of the barrel arbour. Don't ask me why people do this sort of thing, I've no idea. (Picture attached.)
Fortunately damage was limited to the end of the barrel arbour that's used for winding so not too much of a problem. I also managed to straighten the end of the arbour that's used to adjust the time with a little gentle pressure. Guessing it will be weakened but it's now straight and no need to look for spares and hen's teeth.
Have cleaned up the case as best that I can and she's looking a lot better. The movement has been striped and cleaned. There's some wear in some of the pivot holes in the plates which is not a surprise as I don't think that this one has ever been properly serviced. These will be re-bushed with KWM system bushes once they arrive from H S Walsh later this week.
Next step is to strip and clean the platform escapement which will be a first for me. The balance, as expected, is a lot bigger to any watch that I've worked on so can't see too much of an issue apart from gaining access to the end stones to clean and oil. My issue is that I'm not too clear how they are held in place. (See picture attached.)
Anyone come across something like this before who can offer some advice?
Sent from my moto g(6) play using Tapatalk
The barrel arbor is not that bad. Just clean the burs off and polish the end in a lathe if you have one or buff it with emery sticks. It has a thread so it should have a key that is screwed to the arbor. Do no attempt to remove the end stones to the platform; you will never get them back in correctly. If you have a watch-cleaning machine clean all the platform parts in that less the balance wheel, clean that in Ronsonol lighter fluid.
These are good movements I have two 8-day clocks with fully jewelled platforms. These clocks are extremely good timekeepers and will only be a few seconds out in a week. There are some made with only 5 jewel platforms and the real early one have no jewels at all.
Thanks before the advice OH on the platform escapement. I'd also not considered that the barrel arbour may have had a thread on it that had been ground off. I'm guessing that someone has modified a barrel from an earlier movement that had a thread on it rather than one where the key is held in place with a set screw. Will try my hand at tidying it up.
Photo above gives a side view of the barrel arbour taken as I dismantled the movement.
You might find this a good read as an intro to the topic of platform escapements.
http://www.nawcc-index.net/Articles/LaBounty-ServicingAPlatform.pdf
Not sure I’m a fan of craytex to clean pivots. Ideally if they need that, then a jacot tool is the right answer,  but otherwise this is all good stuff.
Thank you for the link, had not seen this before. I can see it being a useful read.
  • 11 months later...
I have an Elliott clock with precisely the same movement as OldHippy's photograph above and the numbers have fallen off the dial blocking the passage of the hands.  I am a complete novice but I would like to be able to stick the numbers back on and get the clock running again (as it is a sentimental value family piece from my wife's family).  I thought that, if I removed the screws from the back (some of which are missing), I would be able to pull out the cylindrical movement, giving me access to the face.  I have tried that and the movement isn't budging out of what appears to be a solid wood case.  Can anyone help me with an explanation of how to get to the face of my clock?
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
