Elliott 8 day platform escapement
nad
Currently working on what I believe to be an early 80’s Elliott 8 day clock that's in need of some attention.
While it was running when it came into my possession it was losing 20 minutes over 5 days so needed some attention. She's not had the easiest of lives and it showed. At some stage it looks like someone has taken a Dremel to it, I'm guessing to try and “Polish” things up but they only managed to grind parts such as the end of the barrel arbour. Don't ask me why people do this sort of thing, I've no idea. (Picture attached.)
Fortunately damage was limited to the end of the barrel arbour that's used for winding so not too much of a problem. I also managed to straighten the end of the arbour that's used to adjust the time with a little gentle pressure. Guessing it will be weakened but it's now straight and no need to look for spares and hen's teeth.
Have cleaned up the case as best that I can and she's looking a lot better. The movement has been striped and cleaned. There's some wear in some of the pivot holes in the plates which is not a surprise as I don't think that this one has ever been properly serviced. These will be re-bushed with KWM system bushes once they arrive from H S Walsh later this week.
Next step is to strip and clean the platform escapement which will be a first for me. The balance, as expected, is a lot bigger to any watch that I've worked on so can't see too much of an issue apart from gaining access to the end stones to clean and oil. My issue is that I'm not too clear how they are held in place. (See picture attached.)
Anyone come across something like this before who can offer some advice?
Sent from my moto g(6) play using Tapatalk
The barrel arbor is not that bad. Just clean the burs off and polish the end in a lathe if you have one or buff it with emery sticks. It has a thread so it should have a key that is screwed to the arbor. Do no attempt to remove the end stones to the platform; you will never get them back in correctly. If you have a watch-cleaning machine clean all the platform parts in that less the balance wheel, clean that in Ronsonol lighter fluid.
These are good movements I have two 8-day clocks with fully jewelled platforms. These clocks are extremely good timekeepers and will only be a few seconds out in a week. There are some made with only 5 jewel platforms and the real early one have no jewels at all.
Thanks before the advice OH on the platform escapement. I'd also not considered that the barrel arbour may have had a thread on it that had been ground off. I'm guessing that someone has modified a barrel from an earlier movement that had a thread on it rather than one where the key is held in place with a set screw. Will try my hand at tidying it up.
Photo above gives a side view of the barrel arbour taken as I dismantled the movement.
You might find this a good read as an intro to the topic of platform escapements.
http://www.nawcc-index.net/Articles/LaBounty-ServicingAPlatform.pdf
Not sure I’m a fan of craytex to clean pivots. Ideally if they need that, then a jacot tool is the right answer,  but otherwise this is all good stuff.
Thank you for the link, had not seen this before. I can see it being a useful read.
  • 11 months later...
I have an Elliott clock with precisely the same movement as OldHippy's photograph above and the numbers have fallen off the dial blocking the passage of the hands.  I am a complete novice but I would like to be able to stick the numbers back on and get the clock running again (as it is a sentimental value family piece from my wife's family).  I thought that, if I removed the screws from the back (some of which are missing), I would be able to pull out the cylindrical movement, giving me access to the face.  I have tried that and the movement isn't budging out of what appears to be a solid wood case.  Can anyone help me with an explanation of how to get to the face of my clock?
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
