Fly Pinion required
clockboy
Working on a large French clock this afternoon and while assembling the plate snapped shut and broke the fly pinion. Just by any chance has anyone got one of these in their scrap/spares box.
The dimensions are as follows:
It has 7 leaves with a diameter of 2.25mm
The shaft is 1mm diameter
The total length I estimate should be 34mm
I have gone through all my spare clock parts and movements and no luck not even one I can modify.
Pinion2.thumb.jpg.72fbe21f61973e5f2650758937134559.jpgPinion1.thumb.jpg.d2f2435f324c31a0266fb6f77d45e690.jpgPinion3.thumb.jpg.31778bcc4dc633e4c802ae613dbef39b.jpg
I have not got a pinion cutter so re-pivot is not straight forward. Also with such a small shaft I don't think I can drill and insert a pivot end. I am looking at a pinion cap, I have never used one before but at present that is my only option.
8 minutes ago, watchweasol said:
Hi Clockboy   They are brittle  on french clocks.  will have a look in my french clock  bits tomorrow, I have a few movements and misc parts. Fingers crossed,   I have a pallet arbour to do someday will get round to it.
Thanks watchweasol I have read that but I am a bit lost with this one. The pivot end is 0.040 so really easy to break as I found !!!!. It's been a while since I broke something but what fun !!!!!!!
Hi Clockboy    I have had a look at what I have, I have 3 fly arbours as follows  7 leaf with a dia of 1.88 shaft length 33.3 and shaft dia of 0.99mm these measurements were taken using a vernier not a micometer so may not be deadly accurate.  What is the movement is the broken one from as these are I think ab mougin/Japy feres units  If you think they will fit or would like to try one no problem just let me know where to send it
Thanks watchweasel unfortunately they will not fit. The movement is french and is very similar to a japy feres however stamped on the plate is GRANGE & BETOUT A PARIS. I might have found one on the bay and I have also sourced a fly that I think I can modify. Also as a last resort I can make the pivot caps work. The correct repair is to re-pivot BUT i have had failures in the past with this and as the shaft is only 1mm in dia. I don't want to risk a mishap with a customers clock.
PS thanks for your time with this I will update as I progress (hopefully)
11 hours ago, Lenj said:
Hi Clockboy,
How you getting on with the French clock fly?? I have an old Frence clock plates measure outside 35mm inside 30.4 approx. sizes. any good to you let me know and I will strip, (the clock the is)..
Len
Thanks Len unfortunately just a bit too short. The inside measurement of the clock I have is 32.5 mm outside inside measurement 37.5mm. I think I am going to convert one I have off a large clock but still not sure this will work.  It should be re-pivoted but I am not confident of drilling dead centre in a 1mm diameter shaft. Thanks again Len much appreciated.
PS I am wondering if a clock could run without one fitted as they are only really a wind brake.
The fly acts as a governor without it when it comes to striking it would be so fast God knows what It would sound like, also the spring would rapidly run down.
Ok I won't do that then.
  • Sad 1
OK no problem, I had another look, all the others are smaller movements, sorry I can't help. As OH said, without the Fly, it would go like the clappers..Have you had any more luck finding one??
No luck as yet Len. So I am now attempting to re-pivot but although I have managed to centre the drill on the 1mm shaft I am having issues getting the drill to drill into the shaft. I have broken several drills @ £5.00 each so it is a struggle at present.
French clock pivots are like glass, need plenty of annealing, and a slow drill. £5 a pop is expensive drilling, wish I had a fly here for you..Good luck drilling..
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
