Fly Pinion required
clockboy
Working on a large French clock this afternoon and while assembling the plate snapped shut and broke the fly pinion. Just by any chance has anyone got one of these in their scrap/spares box.
The dimensions are as follows:
It has 7 leaves with a diameter of 2.25mm
The shaft is 1mm diameter
The total length I estimate should be 34mm
I have gone through all my spare clock parts and movements and no luck not even one I can modify.
Pinion2.thumb.jpg.72fbe21f61973e5f2650758937134559.jpgPinion1.thumb.jpg.d2f2435f324c31a0266fb6f77d45e690.jpgPinion3.thumb.jpg.31778bcc4dc633e4c802ae613dbef39b.jpg
I have not got a pinion cutter so re-pivot is not straight forward. Also with such a small shaft I don't think I can drill and insert a pivot end. I am looking at a pinion cap, I have never used one before but at present that is my only option.
8 minutes ago, watchweasol said:
Hi Clockboy   They are brittle  on french clocks.  will have a look in my french clock  bits tomorrow, I have a few movements and misc parts. Fingers crossed,   I have a pallet arbour to do someday will get round to it.
Thanks watchweasol I have read that but I am a bit lost with this one. The pivot end is 0.040 so really easy to break as I found !!!!. It's been a while since I broke something but what fun !!!!!!!
Hi Clockboy    I have had a look at what I have, I have 3 fly arbours as follows  7 leaf with a dia of 1.88 shaft length 33.3 and shaft dia of 0.99mm these measurements were taken using a vernier not a micometer so may not be deadly accurate.  What is the movement is the broken one from as these are I think ab mougin/Japy feres units  If you think they will fit or would like to try one no problem just let me know where to send it
Thanks watchweasel unfortunately they will not fit. The movement is french and is very similar to a japy feres however stamped on the plate is GRANGE & BETOUT A PARIS. I might have found one on the bay and I have also sourced a fly that I think I can modify. Also as a last resort I can make the pivot caps work. The correct repair is to re-pivot BUT i have had failures in the past with this and as the shaft is only 1mm in dia. I don't want to risk a mishap with a customers clock.
PS thanks for your time with this I will update as I progress (hopefully)
11 hours ago, Lenj said:
Hi Clockboy,
How you getting on with the French clock fly?? I have an old Frence clock plates measure outside 35mm inside 30.4 approx. sizes. any good to you let me know and I will strip, (the clock the is)..
Len
Thanks Len unfortunately just a bit too short. The inside measurement of the clock I have is 32.5 mm outside inside measurement 37.5mm. I think I am going to convert one I have off a large clock but still not sure this will work.  It should be re-pivoted but I am not confident of drilling dead centre in a 1mm diameter shaft. Thanks again Len much appreciated.
PS I am wondering if a clock could run without one fitted as they are only really a wind brake.
The fly acts as a governor without it when it comes to striking it would be so fast God knows what It would sound like, also the spring would rapidly run down.
Ok I won't do that then.
  • Sad 1
OK no problem, I had another look, all the others are smaller movements, sorry I can't help. As OH said, without the Fly, it would go like the clappers..Have you had any more luck finding one??
No luck as yet Len. So I am now attempting to re-pivot but although I have managed to centre the drill on the 1mm shaft I am having issues getting the drill to drill into the shaft. I have broken several drills @ £5.00 each so it is a struggle at present.
French clock pivots are like glass, need plenty of annealing, and a slow drill. £5 a pop is expensive drilling, wish I had a fly here for you..Good luck drilling..
    • Thanks again for all the help. I found a number on the movement (715) after much searching. I guess it's the below movement so I will order than and see how I get on. https://www.ronda.ch/en/productfinder/caliber/715
    • Hi. Thing to do is measure the battery space.  Diameter.  X depth ..    I have seen it listed as  sr626sw.  377 measure to check then check the dimensions of the 377.
    • Hello!  Does anybody have this tool?  This is mine.  If you have one, does it look complete?  How do you use it.  (I have the instruction sheet but it's hard to read!)  thanks!
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
