Fly Pinion required
clockboy
Working on a large French clock this afternoon and while assembling the plate snapped shut and broke the fly pinion. Just by any chance has anyone got one of these in their scrap/spares box.
The dimensions are as follows:
It has 7 leaves with a diameter of 2.25mm
The shaft is 1mm diameter
The total length I estimate should be 34mm
I have gone through all my spare clock parts and movements and no luck not even one I can modify.
Pinion2.thumb.jpg.72fbe21f61973e5f2650758937134559.jpgPinion1.thumb.jpg.d2f2435f324c31a0266fb6f77d45e690.jpgPinion3.thumb.jpg.31778bcc4dc633e4c802ae613dbef39b.jpg
I have not got a pinion cutter so re-pivot is not straight forward. Also with such a small shaft I don't think I can drill and insert a pivot end. I am looking at a pinion cap, I have never used one before but at present that is my only option.
8 minutes ago, watchweasol said:
Hi Clockboy   They are brittle  on french clocks.  will have a look in my french clock  bits tomorrow, I have a few movements and misc parts. Fingers crossed,   I have a pallet arbour to do someday will get round to it.
Thanks watchweasol I have read that but I am a bit lost with this one. The pivot end is 0.040 so really easy to break as I found !!!!. It's been a while since I broke something but what fun !!!!!!!
Hi Clockboy    I have had a look at what I have, I have 3 fly arbours as follows  7 leaf with a dia of 1.88 shaft length 33.3 and shaft dia of 0.99mm these measurements were taken using a vernier not a micometer so may not be deadly accurate.  What is the movement is the broken one from as these are I think ab mougin/Japy feres units  If you think they will fit or would like to try one no problem just let me know where to send it
Thanks watchweasel unfortunately they will not fit. The movement is french and is very similar to a japy feres however stamped on the plate is GRANGE & BETOUT A PARIS. I might have found one on the bay and I have also sourced a fly that I think I can modify. Also as a last resort I can make the pivot caps work. The correct repair is to re-pivot BUT i have had failures in the past with this and as the shaft is only 1mm in dia. I don't want to risk a mishap with a customers clock.
PS thanks for your time with this I will update as I progress (hopefully)
11 hours ago, Lenj said:
Hi Clockboy,
How you getting on with the French clock fly?? I have an old Frence clock plates measure outside 35mm inside 30.4 approx. sizes. any good to you let me know and I will strip, (the clock the is)..
Len
Thanks Len unfortunately just a bit too short. The inside measurement of the clock I have is 32.5 mm outside inside measurement 37.5mm. I think I am going to convert one I have off a large clock but still not sure this will work.  It should be re-pivoted but I am not confident of drilling dead centre in a 1mm diameter shaft. Thanks again Len much appreciated.
PS I am wondering if a clock could run without one fitted as they are only really a wind brake.
The fly acts as a governor without it when it comes to striking it would be so fast God knows what It would sound like, also the spring would rapidly run down.
Ok I won't do that then.
  • Sad 1
OK no problem, I had another look, all the others are smaller movements, sorry I can't help. As OH said, without the Fly, it would go like the clappers..Have you had any more luck finding one??
No luck as yet Len. So I am now attempting to re-pivot but although I have managed to centre the drill on the 1mm shaft I am having issues getting the drill to drill into the shaft. I have broken several drills @ £5.00 each so it is a struggle at present.
French clock pivots are like glass, need plenty of annealing, and a slow drill. £5 a pop is expensive drilling, wish I had a fly here for you..Good luck drilling..
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
