How to remove stem from this JLC
AP1875
No idea how it could have happened, but it appears the roller table is turned about 15 degrees from normal. In the pic with the balance at rest, the arms are perpendicular to the fork. This is normal. With the roller turned like that you’ll have a massive beat error though.
That it doesn't run may be as simple as the fork being on the wrong side of the roller jewel after reinstalling.
23 hours ago, Nucejoe said:
Not just your gut feeling, Note when he tries to get the balance moving with tweezers, the wheel will go some 20 degrees  for impulse to recieve impact from the fork. I didn,t know that accounts for such low amplitude or dose it.
So bring the stud career back, until the slightest turn of the balance in either direction moves the fork. You can observe the fork and pallets from top view.
It looked more like 20 degrees to me.
Hi Nickelsilver, I check everything I suspect, I learned here, that is how I make up for my lack of experience. So here is the towel and   :Bravo:    :geek:      :lol:
Hi guys, I've got a little lost in the terminology, which part has turned 15/20 degrees?
The roller table. Sorry, on phone, so hard to bring up an image. It's what's on the balance staff and holds the roller jewel. In 99.99% of cases (and clearly in yours) the roller jewel should be at 90 degrees to the balance arms. They should be at 90 degrees to the fork (line from escapeme wheel pivot jewel to balance pivot jewel).
Hi, the position ballance wheel comes to rest when movement stops, is about 15 degrees ahead of the point where the fork transfers energy to impulse jewel.
Seems like the roller is set correctly  but the HS is set 20 degree off, making the angle between impulse-center-stud 20 degrees too wide.
Either roller table or hs set wrong, same difference.
Edited by Nucejoe
So, I’m definitely out of my depth here but let’s see if I can learn.
Do you mean this part highlighted in red (sorry for the dodgy arrow drawing with my finger on phone).
How do I go about resolving this? Thank you guys for all your help
I added a picture above, I thought I quoted you in the post. Thank you
I,d say wait, lets make sure, before you mess with it. This is a dangerous zone , too much hairspringly.
Yes definitely. I’d practice on another hairspring first.
I’m still perplexed how this could happen without touching the movement....
Don’t worry, everything is on me. I take full responsibility for anything I do. I’m pretty good at this sort of thing, and usually get it right. I have to fully understand what the problem is and what I’m doing though and in this instance I do not, so will not be attempting anything just yet
Yes that is the roller table. Visit eternaltools.com to see  movement parts illustrated and listed with corresponging names, according to eta. Some parts may have been called different names by different sources/manufacturers.
If you are intent on trying it, I will post pictures to show you how as walkthrough.
You will be removing/repositioning the roller on staff. This should give you an idea.
Remove the ballance. Remove the HS. Grip the roller in your pin holder, slightly rotate it clock-anticlock to loosen the roller off of staff.
Reposition the roller prependiculare to spokes, tap to tighten the roller on the spokes.
Reinstall the HS so the stud is at 90 degree angle with impulse pin.
Hi guys,
Sorry for going quiet. I found another balance for sale so I ordered it. I thought I’d wait until it arrived before I asked anymore questions.
Anyway I have it. It’s a bit old and could do with cleaning but I installed it in my movement and it works.
I put the two side by side and took some images. Apologies for the focus, this microscope has a poor resolution monitor and the tiny d.o.f at this magnification can make it hit or miss.
Looks like that jewel is slightly out of place other than that I can’t see anything. What do you guys think?
I am pretty sure Nickelsilver hit the nail on the head. So once you get ready to adjust the roller on the old one, I,ll be happy to work with you till fixed.
I think you like your JLC I kinda understand your passion for the jewel . I too am fond of the brand and like the jewels they make.
Yes it does look different. Thanks for offering to help.
@nickelsilver does this confirm your suspicions?
I think I need to practice on some cheap Chinese 2824 movement first...
On 1/26/2019 at 4:01 PM, Nucejoe said:
For now I  bring back the stud carrer ( clockwise) as far as you can,( risk free) and observe if beat error improves
Before playing with the roller did you do this suggestion which I've quoted above? It's amazing how much of a correction you can get by moving the stud holder or if somebody bumps it and it's not where it's supposed to be. So as you can understand what were suggesting you do I'm attaching an image.
Ideally you should be visually looking at the pallet fork verifying that you're in beat visually because if you're paying attention to the timing machine it's really easy to go past where you're supposed to be and get hopelessly lost. So visually need to be in beat reasonably close before you start pushing it on the timing machine.
JohnR , Stud career is nearly all the way back ( anticlock based on your diagram)  yet impulse is not in beat, AP must be hearing     ti tic --- tic .
I told him about getting the impulse inside the horns( in beat) he dosn,t feel comfortable to attempt now. Understandable beatiful jewel.
Hi   having read all the reply's de-power the mov't remove balance and fork then wind one turn or more as required and see if the train wheels rotate freely, It may be that having wound the movement in the first place some dirt in the barrel is blocking the M/spring, or it could be broken and slipping or even a damaged tooth some where. Doing the above will prove the power train is working, do not over power the movement with the fork removed, Look for low drive on the train
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
