Watch only works upside down
Hello, today I picked up an old, not working watch that i have had lying in a drawer a long time. It did not tick at all and I am quite sure the main problem was that the pallet fork was stuck in its jewel sitting and could not move at all.
I cleaned and re oiled the movement and not it only works when I lay it upside down, or at least it does not work with the right side up. It ticks a few seconds but then stops.
Any tips on what could be the problem? I know that there are about a hundred different possible problems but since it works fine upside down and not at all otherwise I figured someone might have had the same problem. (It seems to be worse during a specifik time of each minute, but not just at one point but rather during a 15 sec period of each minute).
Thankful for any answers, Jakob
That would be my first guess as well, something amiss with the balance staff.with the watch dial down gravity would tend to pull it down so the impulse jewel would engage the pallet.With the watch dial up its sounds it might not be.
.. all of the above, and check for foreign bodies obstructions that may have been introduced while cleaning.
I had a small hair mysteriously appear in one watch that I was working on, which caused a similar issue. Worst of all, the watch worked reasonably well till I cleaned it.
The hair was nicely attached to the top plate and dangled down when the watch was face up, obstructing the palette fork, but moved nicely out of the way when the watch was face down. The hair looked suspiciously like one of mine, but I didn't do a full DNA test. :unsure:
  • 5 years later...
Same thing happened to me. Cleaned and oiled a movement and would only work upside down. I noticed a couple of the coils on the balance spring were stuck together (from my poor oiling) so I re-cleaned and it worked fine.
    • I'm sure you will get help on here soon.  Kkramme we like new members to make an introduction before posting. A little about your self such as where you life and what got you interested in Horology
    • I'd be grateful for recommendations of good sources of advice on getting clocks with balance spring - as opposed to pendulum - escapements 'in beat'.....
    • Well I am in a bit of a quandary. I can't find the correct colour for the dial. I even wrote to Hettich a while back hoping they would give me the colour code for the dial. The reply that I received was "We don't make those anymore." I am thinking now to silver the dial and use a water transfer decal to put minute markers and the HETTICH logo (which is the very font that this forum uses) and the Made in Germany down the bottom. Not sure of the success rate of the water transfer method, but I have no other solution for the markers and logo. Handpainting is just not an option. In trying to get the top piece of the clock polished, it has progressively lost its sharp edges. My stupid hamfisted effort. I am thinking of purchasing a replacement piece of brass and drilling new holes in it for the corner posts. Why I attempted to repolish using wet & dry and not simply using a paint remover to remove the old lacquer from the brass, I don't know. You whistle and I'll point at the idiot. I also need to purchase some sheet spring steel as the two small ratchet springs that arrest the wheel that supports the weight after it is lifted by the electromagnet are worn. The two from the donor clock that I purchased are worse. I am hoping that I will be able to manufacture new springs without having to fiddle about with tempering etc to the steel. I have some ideas on that front. How many things until the clock is no longer the original? Like an axe. Heard a woodchopper on tv once saying that he had replaced the head on his axe twice and the handle three times, but it was the same axe that he began woodchopping with. 😉 I must post more often or read back through what I have previously written. Keep repeating myself. Sigh.
    • I use the exact OD and it fits in with a little force and a pleasing 'click' so it's snug and wont rotate within the holder, but that depends on how you have set up and calibrated your printer so you may need to play with the settings/dimensions a little to allow for any discrepancies in your printer calibration. PS I just finished (2 days ago) a new revision which automatically prints the movement OD on the bottom of the holder, I'll see if I can upload it here Here is rev 4 remember to change the .pdf to .FCStd so it will open in FreeCAD - also you may need to install the LiberationSansBold font and tell FreeCAD where it lives on your PC, or change the font to something you already have on your system. Para Movement Holder V4.pdf Examples below:
    • Only someone on this forum would ever understand the Oooooo I just did
