Hairspring help - how do I make corrections to overcoil?
mikepilk
My least favourite task is trying to correct hairsprings, especially overcoils ... and my next project has that problem.
I'm putting together a Universal cal 267 and found the hairspring distorted. I've got it looking fairly flat, and not too bad 'in the round'.
The problem is the overcoil. The stud is too high, and I end up with coned coils when it's mounted.
To get the overcoil parallel, I need to start by bending down at 'A', and then probably another correction half way to the stud.
How do I make up/down bends on an overcoil? Is it by using two pairs of tweezers and twisting, as you would fix a twist in the main spring.
In which case, how do you do it without messing up the coils below?
Or do you just grasp it and make a vertical bend - is this possible ?
Surely you agree, bending and unbending lowers fatigue threshold, in simple terms some moleculare bonds in the structure brake, such deformities would be the weaker length of the moleculare chain. In simpler terms you weaken h/s structurally as you bend and unbend, furthuremore you would be shortening the functioning length of the h/s as you raise the overcoil bend.
A longer stud, if you be willing to consider it, solves the problem you are facing,   without creating new ones.
I rarely see Breguet coils that were not distorted...
You must twist opposite of the highest point, using 2 tweezers: there is a good chance that A is the right place. The stud should not go much lower (maybe a bit) else it may touch the spring "dial up".
The coil in the regulator pins area must be concentric, looks different here.
I also suspect, the whole curve after the knee is a bit too far outwards.
Frank
Frank
I find twisting using two tweezers difficult - two pairs of tweezers, enough magnification and light all in the same area!
I can do it with the tweezer tips  on a hard surface, but how do you do it in the middle of the overcoil - tweezers just hovering in the air?
I can do a slight bend down at the elbow as I can just push the tweezer tips outside the last coil.
I agree that the coil does need bending in a bit, and I'll shape it to the regulator pins.
You have done a fine job so far, perfectly level nicely concentric . I add the palm of my hand to my tools.
The palm of your hand is equipped with feel and capable of outperforming other surfaces ,  gives you perfect access to the piece, variable angle of attack. takes part in numerous operations ....advantages are too many to mention. All you got to do is accept it as tool and get used to it, it will do wonders. The h/s will be contaminated and would need to take a bath in lighter fluid,  but shaped just as you want it.
This spring is very easy to work on.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
