AS 1194 Accuracy
Well recently serviced a Louis branded watch. It has a 1950's AS 1194 movement.
It was running about almost dead on for the first few days, now it's running about 20 sec slow. I do not have a time grapher yet. Doing it the old fashioned way. Anyway what kind of accuracy can I expect out of this movement? Or may be too much oil on the pallet stones? Any advice?
Thanks
Sent from my SAMSUNG-SM-G890A using Tapatalk
I'm 99% sure that oldhippy is saying to use very little oil on the actual pallet stones on the pallet fork itself. You don't oil the pivots on smaller watches, which most vintage wrist-watches fall into. On larger pocket watches, oiling the pivots is OK, and probably advisable. I don't remember the exact size cut-off for oiling vs non-oiling. I had a few watches that were giving me grief until I found this out and corrected the situation. Good luck.
Edited by MrRoundel
Never oil the pallet fork.
Ok think that maybe my problem. Still learning. So I oiled the pallet fork pivots and probably put too much on the stones. So time for a disassemble to clean the escape wheel and pallet fork and try again.
I have the red and black dip oilers. Which one should I use for oiling? Also how to get a tiny amount of oil on the stones?
To oil or not to oil!
I'we begun to oil the pallet stones, it actually says synthetic grease on the little bottle of Moebius 9415 not oil but in the oiling sheet from ETA it says oil.
But to oil the pivots of the pallet fork with let's say Moebius 9010 wouldn't be a very good Idea. It's to runny and will find its way to the gap between the pallet cock and the fork.
Since the power here isn't very big it will cause loss of amplitude or bring the movement to a total halt.
I have tried to apply just a thin film of 9415 on the pivots before installing the fork and that seems to work and makes the friction even less than without lubricant. As for the need of a lubricant here the question is already answered. No.
Found this article on the AWCI site about lubricating the pallet stones.
https://www.awci.com/watchmaking-excellen/lubrication/
There seems to be some confusion about oiling a watch escapement.
Use the finest oiler
The pallet stones are to be oiled. Never oil the pallet pivots and never oil the pallet fork.
Oil the escape wheel pivots.
Oil the balance pivots
You do not need to oil the teeth of the escape wheel, the oil on the pallet stones will do this by the rotation of the escape wheel and its coming into contact with the pallet stones.
So, oldhippy, are you saying that it's inadvisable to oil the pallet pivots on larger pocket watches? I'm just curious. I never had noticeable ill effects from doing so on 12-18s movements. I only had issues once I started working on wrist watches and carried that technique over.
Regarding oiling the stones and not the escape wheel:  that's interesting, but I like it. It seems virtually impossible to get the right amount on the teeth on the escape wheel without it spreading too far. Thanks for sharing your learned experience. Cheers.
I have a few of these.I would tell you that they are more reliable than they are accurate.Fifty years old and more they may have quite a bit of wear.I think that they also suffer from hasty assembly.They seem to show more than a bit of beat error,within a minute or two a day is about the best you can expect.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
