My Demagnetiser is Magnetising
margolisd
On 1/20/2019 at 9:14 PM, margolisd said:
Yeah, thanks Tmuir you are indeed correct. Preventing the HS from vibrating causes it to demagnetise. I put it in a plastic bag and held it gently in my fingers and it worked.
Does this mean it's best to remove the hairspring to demagnetise a watch movement and do the HS separately? As I'm sure it was my attempt to demagnetise a movement that ended up magnetising the HS in the first place.
Another thing that seemed to help, before I was only holding the button down and moving the object about half a meter out of the field. A full meter as suggested by ecodec actually seemed to make a big difference.
Thanks everyone. Mystery solved.
Glad I helped.
To give full credit I was told this by a lecturer at one of my night classes at the watch and clock school I attend.
I have demagnatised whole watches successfully before, but only using an expensive Greiner Magnomatic Demagnetiser unit that has built in decay, so you don't need to move it away at my watch school, never on my cheap Chinese demag. Also when the hairspring is in place both ends of the spring are restrained which won't completely stop the vibration, but will limit it.
I also agree that the full meter is important, I basically move it as far away as I can stretch my arm
You can see the same thing happen with tweezers if you try to demag them by only holding the end and leaving them open, they will vibrate in the magnetic field and won't demag properly, but will if you hold them closed and slowly move them away as you say up to a meter.
I would love to have the demag unit that is at my school, but as they cost £850 new I can see me staying with my $5 Chinese unit for a while yet.
  you should still be able to find vintage watch de mags. on ebay .      if they don't work ,  it is a simple fix as its just a copper coil soldered to 110 volt, 60 cycle plug end -----  I DON'T KNOW  if they are diferent on UK  curent, but they sure work good in the US.  vin
If you are de-magging a whole movement then try and do it running as not only are both ends of the H/S restrained from the motive influence of the field but the spring itself is moving independently of the magnetic field, further enhancing the efficacy of the method.
Interesting stuff. I'm working on quite a tiny movement at the moment and I don't know if that has something to do with it. But when I demagnetise the movement, even though the hairspring is fixed in place and running, it is magnetising the HS. When it comes away from the demagnetiser it instantly forms a cone shape and the movement starts going super fast. It seems the only way to demagnetise this movement successfully is to remove the HS first and demagnetise it separately.
  • 3 years later...
oh I'm so happy! I bought this device under the impression that it magnetized things ..then google told me it was a demagnetizer!! I was so sad until I watch that YouTube video..now I know it is simply: BOTH!! Even better..why are we against this concept at any degree!!?? Multi purpose tools are the BEST!!! K thanks!
Pearl
Pearl
I think watchmakers like things demagnetized.  Auto mechanics like things magnetized.  So, there's that.
The concept is fine if people know what they're doing. It's a lot easier to use a tool if it has a single function if you can end up magnetizing your watch because you don't really know how to use the tool then that's a problem.
That is an interesting concept Would that prevent the screws from all sticking together? Fortunately my tweezers Cannot magnetized or it would be a real problems the screws stuck to the tweezers. Then it's sad I can't even demagnetized the entire watch as that would ruin the magnets on the tuning fork.
Not just auto mechanics it's really nice to have magnetized screwdrivers when you're working on a computer. That way if you drop a screw into the case which typically do it easy to get it back out again.
I worked with a Japanese guy who swore by wrapping the balance complete in watch tissue. It actually solved issues for me (very small jlc calibers). I have the Greiner Magnomatic (and sister machine that detects magnetism) .
Edited by nickelsilver
Very few of us are born with all the information we and those around us will need.  It all just build, layer upon layer.
Good form though.
I use the coil out of a 240v motor contactor and run it on 110v.  Works pretty good.  I have seen some 24v contactors rated for AC/DC that had an internal diode to protect control circuitry.  They won't work and will just magnetize stuff.
18 minutes ago, LittleWatchShop said:
not with NTSC system.
Sorry, apparently that was an old Radio neuron not an old TV neuron.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
