Longcase clock very bad marriage.
oldhippy
It is not a marriage it is a 3some :o , the movement does not belong to the dial, the dial does not belong to the case, the movement does not belong to the case. Look at the seating board, one attachment hook is in the right place, i.e. almost directly under the pillar the other is way off, see the gap around the dial it is smaller than the frame. It looks like it was put together by Frank Spencer (Some Mothers do Have Them fame).
    • Hello and welcome from Leeds.
