eta 2784 question
This was an interesting question, I'll take a first shot!
Sounds like a mainspring unwinding in the barrel.
It might be the little indentation on the side of the barrel that become a bit round, it can retain a little bit of tension but finally slips.
That's what I was thinking...not with those professional words.
That isn't normal is it?
You have to take the movement apart, just by sound one  can identify the area that might be subject to repair.
After a closer inspection one can say exact whats erratic or needs to be repaired.
The most likely parts are the barrel, the barrel arbor and/or the mainspring, but you wont know which until you inspect them closely.
It could also be that there is play in the barrel bearings or movement in the plate(s) holding the barrel in place (a broken screw perhaps), allowing the barrel  to rock or slip when there is sufficient tension in the spring.
My money is on the mainspring, but I'm usually wrong.
Thanks! That should be fun. :-I
If the whole barrel is slipping, you can possibly spot that without stripping the thing down. I have an old EB8800 that makes similar noises, in my parts pile, and I know why it misbehaves, because I can see the barrel spinning rapidly when I wind it more than a few turns, because the whole barrel lifts up at one side as it is wound.
The cause is a broken hold down screw on the rather flimsy barrel bridge. The screw head is missing in that mech, and the shaft of the screw is still in the base plate, which is why I haven't bothered fixing it yet, as I haven't had the time or inclination to try to extract it yet.
The EB880 is a pretty basic mechanism, as you can see, and this seems to be a known weakness in that particular setup. It is also much easier to see the barrel in that case, because it is staring you in the face.
The picture above is of a similar (pin lever, rather than jeweled, but working) EB8800 with two unbroken screws, so you can understand what I am talking about.
Watching the barrel on your watch might be a little more tricky. Having said all that, even if you do spot the barrel slipping, you will still need to strip things down to figure out why.
1 hour ago, Nucejoe said:
Judging by the number of turns before release, mainspring dislodges from thr barrel.
When I wear it I don't have any problem, it never stops, but that sound when I handwind it got my attention.
What makes you think it's the mainspring? When that sound comes the barrel does not move...so the sound got to come from inside the barrel, is that the logic?
There aren't that many parts to choose from, barrel, mainspring and the arbor.
Watching the video one can see you wind and the balance oscillate, it means you got power through the drive train.
If the mainspring would be bad by the arbor then you wouldn't have any power since it would  not wind the mainspring at all, now it does and by that tighten itself around the arbor notch.
On the inside of the barrel you have the small indentation I earlier spoke about, the mainspring has a formation which grabbs onto this notch and makes it possible to wind without the spring slipping.
On your watch the spring grips onto this notch until the tension in the spring makes it to slip. As it  unwinds it grows in area and once again grabs onto the notch making your watch run.
So the watch will still run but not as long as it should in a static position.
It is an easy fix but you have to open the barrel to see if it is the end of the spring that is bad or the notch in the barrel.
Forgot to say, when you wear it the auto winder probably nerver winds it enough to release the spring  or you just do't notice it,
Edited by HSL
 Mainspring dislodges from the notch inside the barrel, it's coil turns to unwind to release the power.
The question was, what dose that sound mean? It means the mainspring dislodges from the notch inside the barrel therefore unwinds to release some or all of its power reserve. No telling if the barrel is reuseable or should be replaced before you crack it open.. Should you need any help I get my tools :judge: and stay with you step by setp if neccessary  til fixed.:lol:
Yes that is one good reason/ logic, if you can tell where a sound is generated.
In this case, however,  familiarity with the sound and commonality of the culprit helps a lot.
Manufacturers recommend MS removal routinely at periodic cleaning/services, MS springness weakens by use. Use of right grease and oiling the arbor is a must. Some barrels says do not open.
As OH puts it, you don,t know what is happen inside unless you open the barrel.
1 hour ago, panchoskywalker said:
I was more thinking about looking for a complete barrel to just replace it, not sure if I have the guts to open the barrel, would probably find the way to stick that spring into my eye.
That is certainly an option. They should be available, and hopefully not eye wateringly expensive either, however it may be possible to fix the one you have. Just put on your safety specs and crack it open.
I think a 2770 series barrel and mainspring would be correct, but check before you purchase.
Something like this perhaps - https://www.ebay.co.uk/itm/ETA-Calibre-2770-Part-182-Complete-Barrel/222524899179?hash=item33cf847f6b:g:NLkAAOSw4CFYwvVt
Also confirm with the supplier that it includes the spring.
Edited by AndyHull
As the price indicates these usually comes with just the barrel drum and cover.
The problem with buying complete parts to old movements is that you don't know when it was fabricated. Old non synthetic oils gets bad with time and it ends up you have to pop the cover sooner or later anyway.
Edited by HSL
Agreed. At some stage, you are going to have to bite the bullet and take a look at the spring, whether it is the old one, or the replacement.
Besides it may be a simple fix, so you might not need to stump up for one or other or both of the  barrel and/or the spring.
I guess it could be simply that everything is so gummed up with old oil and dirt, that the spring simply isn't catching on the barrel. Alternatively, it might only take two minutes with a sharp file to fix the issue.
Furthermore, in the extremely unlikely event that you do take an eye out with the spring, whats the problem? You can still see to type "I told you so" with the one remaining good one. :devil:
Edited by AndyHull
26 minutes ago, HSL said:
Guess I'm a little bit zealous sometimes, but found  out the hard way it is just easier to bite the bullet and take the loooooong way and make it correct from the beginning.
I agree, shortcuts often turn out to be the long way of doing things. As the old adage goes, check it twice, fix it once, or to put it another way, you need to fully understand a problem before you can resolve it.
Edited by AndyHull
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
