Helvetia cal 81-24 mainspring check
cduke
Hello Friends
i have a newbie question on checking a mainspring on a Helvetia movement. Without getting to the mainspring, is it possible to determine if the spring is broken? Watch will wind (not run) to full resistance. I assumed that if the spring were broken the watch would wind indefinitely. Is this true?  Getting to the mainspring involves quite some work and I am not sure how to diagnose.
thank you all again for the lessons.
If you can wind the watch right up, then the mainspring has not broken. if it had broken as you say you would be able to wind it for evermore. Depending on the movement, sometimes you are able to just remove the barrel bridge to access the barrel and replace the spring. Myself I never liked this way because you will dislodge dirt that can get into the train and it will stop the watch. It is always best to do a complete clean.
  • Thanks 2
Hi C     Yes you said it, winds to full resistance.
Release the reserved power through the click, rewind and  repeat several times, you should get to full wind by same number of smooth turns,  about 20 to 30.
If broken , it turns indefinate as you said or wind some and suddenly discharges the reserved power, depending on the length of broken piece.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
