Jewelling question
When cleaning a movement in my ultrasonic a jewel in one of the bridges came out and needs to be put in again using my not so often used Seitz set.1950b9f19b3baebe193f575ffb1dd32b.jpg
When inspecting the hole I note a couple of tiny (maybe 1/4 of the hole diameter)circles at the edge that I started to suspect may come from a previous trial to tighten the hole just slightly with a punch around the hole edge.
I have attached a photo that I hope shows what I think can be the punch marks.
Would this be an ok method to tighten the hole and something I can repeat as I guess the jewel will not sit very safely when pressed in again?
When viewed from the top side, I note that the hole is lined with a brass ring that doesn’t go all the way through. Why were these brass linings used? Softer material?
Can you post a pic of the other side? Sometimes on normal grade pieces they were retouched around the jewel hole after plating to show the brass and give the impression that the jewels were set in chatons.
Hard to tell if a previous attempt was made to close the hole. You can try a domed (convex) punch to close it a little. Try a punch where the round face is about 50% bigger than the hole. I like to do a little from both sides.
Hi,
Photos are attached and I think you are probably correct. Looking closer, what I thought was a boundary between the chaton and the bridge inside the hole, probably is just the edge between plating and brass.
Hopefully you can judge from the photos?
18 hours ago, bsoderling said:
Hi,
Yes, those are "fake chatons". The bridge itself is made to look like it's 3 separate cocks. What's interesting is some makers went through such efforts to make the product look more high-end, while it was fairly certain the only person to ever see the movement would be a watchmaker.
I think the "fake chatons" and general attempts to show off generally dates to earlier in the century when customers were more likely to see the watch movement in the shops, especially if it was a shop-built watch made to order. It was common back then to choose a particular movement and have it mounted in a standard caselike a Dennison model, for example.
One other thing you sometimes see is an enlarged cap jewel which is visible when looking at the balance cock, yet the cap jewel fitted to the plate is much smaller. Purely cosmetics to "wow" the customer.
Then in the 1970's we have the fight for maximum jewel count, with superfluous cap jewels everywhere.
One thing is sure; human behavior never seize to amaze...
A quick update on my progress.
I decided to fit the jewel without trying to reduce the hole first, just to see how loose it would be. When pushing the stone in, after a bit it suddenly shatters in small pieces. I suspect there was an edge or burr or something that pinched too hard at some local point.
Almost caved in at that point but decided to have a look around some other less fortunate movements in my drawers. And indeed, an old pin pallet movement I never got to run had a jewel with the same dimension and this time the pushing-in worked better and the jewel seem to sit safely.
Regarding the technique to reduce the hole with a domed punch, I suppose one has to be very light handed to not overly deform the edge of the hole too much?
As I see it, all the force from the punch will be focused on that tiny area where the dome meets the hole corner. I suppose what one wants is to have material deeper into the hole to expand and reduce the diameter, without creating burrs and deformations on the edge?
One thing to check (which you may have already done) is the hole size (which then corresponds to side-shake) when you selected the new jewel. You can simply take the relevant wheel and sit its pivot in the new jewel hole and observe the angle which the pivot is permitted to move from side to side. You can judge this by eye.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
