    • If you're talking about something like a set bridge or springs and jumpers for a chronograph or similar the standard steel  in the U.S. would be O-1 oil hardening steel. Starrett sells it, you may find cheaper elsewhere. Bergeon used to sell little packs of steel sheet in different thicknesses, you may find some old stock on Ebay. It seems quite similar to O1 in my experience. Other Swiss suppliers used to sell larger sheets in 0.10mm thickness increments but not anymore and it's quite tricky to find in small quantities.
    • The one in the center is labled for clock work very similar to the one you purchased as you can see the watch makers ones are more versatile with all the stakes and stumps and a full array of punches.. I hope this was some use for your information
    • Hi. My name is Brandon. I joined because I want to learn a bit about how to care for my girlfriend's watches and mine as well. We're not collectors or anything. Just casual watch wearers. She started all this. I replaced the battery in one of hers. It was easy. And one ended up being a kinetic watch that she hadn't worn in a long time. But, she has a few more that she wants to get going again and I have one as well. We've already damaged one by breaking the crystal trying to pop the back back into place on one of hers. I warned her I didn't know exactly what I was doing and that i had never done it before but she wanted to try. So, we used a watch press...incorrectly. Got it online. I'm pretty upset with myself. I'm usually pretty good about tinkering and fixing things and I usually do more research before diving into something I've never done before. The instructions for the watch press were lacking and I followed them to a T. We see now where we went wrong, though. Should have done some research and watched some videos on how to use one first. Please don't be too harsh on me lol. I'm taking it to a jeweler today to get the crystal replaced because I don't want to get into that. One of my watches and one of hers both have a back that unscrews. I got the tool needed to remove the back and successfully opened them both without scratching them up to see what batteries they need. It all went well. The battery came out very easily in hers, but mine has some sort of clip or something in the way. It's metal and looks like I might need to remove a small flathead screw to open it up and remove the battery, but I am not sure. So, I'm here to learn mostly. Thanks for having me.
    • Hi rstl99   Yes it looks all there apart from a few gaps these are ok for general work, for balance work etc you need the  proper up right staking tool with rotating table and punches.  If you google watchmakers stanikng set or do the  same on ebay you will see what I mean therer are many makes K&D Star and many more.
    • Super interesting!! I hadn’t seen any staking tool without a shaft to guide the stakes. There has to be a away set things up. I wonder if these sets are more accessories to a basic set rather than the whole tool by itself.
      I’m interested to learn more about this! Let’s see what the gurus have to say
