Inttroduction
Grizzly
Hi Group!
I am brand new to this forum, and wanted to introduce myself.  They call me Hoss Grizzly, but you can call me Grizzly.  Maybe because I am 6'6", and 275 lb.  Anyway,  I am excited to learn and participate in this forum.  I recently decided to start getting serious about learning and collecting instead of admiring from afar. Pocket watches remind me of the good times I had with my Grandfather.  Cheers!
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
