Hi from Cornwall UK
surfluds
Just started on my watch journey after digging up some old watches I used to wear, rediscovered and now have an interest in getting them working again so tinkering and who knows where it may lead.
So will start with the video course and go from there who knows may leave the world of IT for Horology ;)
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
