Quartz watch! Keeps losing time!
bosstaki
Hi guy’s! Looking for help please! I’ve been trying to get a watch running right for a friend of mine but its been to no avail! I’ve changed the battery twice now with brand new battery’s but it still keeps losses time, it’s lost 20mins in 12hours! The second hand doesn’t stick it ticks perfectly in all positions! I’ve checked the watch pulse with my Etic microtest 2000 & everything checks out fine! Ive checked it for being magnetised! Nothing! Any ideas guy’s!
Hi Bostaki,  How is the old county,  It would be helpfull if you could post a picture of the movement and make and model as some of the older makes had trimmers, the newer versions use electronic inhibition in that the cpu monitors the pulses and either put in extra or takes one out as required to maintain the time if thats gone haywire its a movement change, cousins or HS walsh usually can supply most makes.  good luck in your quest                   Ex Tadcaster now Scotland
be160007cb9871b61d29aac50b88e1da.jpg here’s the watch mate, but I’m not sure what the movement is! I’m at work! I’ll pop the back off later and take a look at the moment mate! I’ll let you know!
Your issue sounds like a similar problem to this-> https://www.watchrepairtalk.com/topic/10515-raymond-weil-95145/
I think a lot of the advice there applies here too, so run through the suggestions there.
The issue may be purely mechanical or alternatively electronic.
I would check the battery contacts are clean, and that there is no obvious sign of corrosion anywhere, then inspect the module very carefully for hairline cracks and damaged solder joints.
It doesn't take much with the very low power levels involved for things to get out of whack. A loose connection on one end of the crystal, or moisture damage or a crack to one of the resistors or capacitors, and things get strange when they cool down or warm up.
If you have access to an oscilloscope, things get a lot easier, but assuming you don't, then start with those suggestions first and we will see if we can get to the source of the issue.
Does the movement loose an exact amount per day, or does it vary. Do you have access to a time grapher, (or time grapher software on your PC or phone, for example -> https://tg.ciovil.li/
A time grapher will let you see exactly what affects the rate of the watch (position, temperature, vibration etc). I'm assuming that the movement in question does actually autibly tick. Some quartz movements are so quiet that you would struggle to get the microphone to hear them, and others sweep without ticking.
If the thing is silent, then you would need an oscilloscope to "see" what the movement is doing.
Edited by AndyHull
be160007cb9871b61d29aac50b88e1da.jpg&key=e5e5857de28fe014af39089a6b5f087bbb196c52aba1266864772f660cde6494 here’s the watch mate, but I’m not sure what the movement is! I’m at work! I’ll pop the back off later and take a look at the moment mate! I’ll let you know!
Hi the watch movement is a ISA 307
16 hours ago, Vacherin said:
Maybe time the second hand, is it spot on 60 secs per rotation? Perhaps check it's position exactly on the minute after an hour or two.
This is good advice, and a simple test to confirm if the train is stopping rather than an issue with the motion works and the friction coupling for hand setting.
Looses 20 min/ 12hrs ,  Dose so on bench only? Or on wrist ? Both?
What dose timing the seconds hand show or prove? If it looses 20 min per 12 hrs, the seconds hand will show loss of 100 secomd per hrs. So how would help diagnostic.:blink:. Or have I misundertood your meaning?
And if the seconds hand is the suspect, just remove it and observe.
:wacko::o:unsure: which one is who.
Edited by Nucejoe
20min/ 12hrs, observed for one day only? Loose hand then 20 min may alter.
If you time the thing on a time grapher, then you may see a pattern over time, so it may form a straight line with a jump at regular or irregular intervals, or the time grapher may show that it runs at a constant, but slow rate, or the rate may vary in a sinusiodal manner.
The graph can reveal which part of the system is the most likely source of your error.
Having said all that, the movement is not particularly expensive, so you might find that simply replacing it is the least time consuming and painful option.
Edited by AndyHull
Hi   looked up the movements  cousins    obsolete   HS Walsh non  listed  AG Thomas in Bradford have listed ISA 307 s @ £7.75 might be worth a go and movement swap then play with the old one, probably the cheapest option. Thats what I would do as I have played about with quartz watches only to have wasted time and end up changing the movement .......   best of luck
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
