Hi from Sweden!
Mrrbeige
Hi everyone! thanks for the letting me join.
A few years ago I promised my wife that I should repair her two old pocket watches that had been in her family for years, so now I try to learn as much as possible :).
Have bought some watches to practice on and some tools to use, slowly learning and in some years I think that they will be serviced and running.
Living in Sweden in a small house some woodworking machines in the basement and a homemade pizza oven in the garden.
thanks again
Robert E
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
