Raymond Weil 9514.5
My partner obtained  a quartz Raymond Weil 9514.50for me to  repair, granted its a quartz ugh!!! but it loses 20 mins  a night, but maintains time during the day when worn, have changed the battery but this has not changed the situation, any ideas? can you obtain a new movement reasonably cheaply?? Cousinsuk do not even list the manufacturer.
Comments welcome
Before replacing the movement, it might be worth checking if the hands are making contact with each other at some stage in their rotation.
Repaired a Tissot quartz a while back which was losing time as a result of a slight drag as the second hand passed over the minute hand. When worn it lost a little time but when left on the bedside table for a while it sometimes stopped.
Sent from my moto g(6) play using Tapatalk
If that line of fault finding leads nowhere, then it could be an electrical issue. I'm no expert on quartz movements specifically, but I do have a background in electronics, so I can offer a few suggestions.
I would check the battery contacts are clean, and that there is no obvious sign of corrosion anywhere, then inspect the module very carefully for hairline cracks and damaged solder joints.
It doesn't take much with the very low power levels involved for things to get out of whack. A loose connection on one end of the crystal, or moisture damage or a crack to one of the resistors or capacitors, and things get strange when they cool down or warm up.
If you have access to an oscilloscope, things get a lot easier, but assuming you don't, then start with those suggestions first and we will see if we can get to the source of the issue.
If you post some closeup pictures, then I might be able to offer some other thoughts.
Edited by AndyHull
I havn,t seen a pic of the movement.
If its got day or even date, the day jump works can very well be the fault, advance time by 12 hrs = swith day& night around, it then should loose 20 min day time and go accurate at nights.
Good suggestion. I would try that first before messing about with my suggestions, also some good pictures would help
Thanks, it has no second hand and I followed your advice, sadly I CAN see daylight between the minute and hour hand when placed at 12 noon, so sadly this easy fix seems unlikely. The movement is an  556.031 im told ETA do an equivalent.
Hi andy I guess I get medals only if that fixes the movement.  Remember?  :geek:
Regards joe
Regards joe
No fix, no medal, thems the rules :D
I suspect the movement should look something like this.
It seems it has been superseded by the ETA 956.031/2 Movement (double check that before you purchase though).
My suggestions to check for poor solder, corrosion, cracked components etc. still stand. If you are feeling brave (or foolish) you could try cleaning the mechanicals too. Whats the worst that can happen, you have to replace the movement.
Many thanks, now the fog is clearing, could not find the original movement ref on any site, may just replace the movement.
David
On 1/7/2019 at 6:36 AM, AndyHull said:
It ain't the cheapest movement I've ever encountered, considering it is just a simple two hander :(
http://www.ofrei.com/page548.html
http://www.watchpartssupply.com/eta-9560312-movement-p-297.html
It's Swiss. What else can you expect? I did fine an original 556.031, new,  listed on the US version of fleabay for $400. Ouch! The seller must be assuming that someone wishes to restore a valuable heirloom.
Edited by TexasDon
additional info
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
