Sekonda Click springs
Chadders
I can't find any reference numbers on the movement, it looks similar to a Z2009B but as a complete novice to watch repair i'm a bit stumped. The old spring had rusted and snapped so I'm not sure what the original actually looks like. It seems to originally had 2 x 90 deg bends at either end which are a) captured by a locating hole on the chassis,bridge of the watch and b)the other end is caught by the rotating click plate? I could really use a glossary of terms so I can describe the problem better. Either way it won't wind or hold the energy of the main spring. Its not an expensive watch, it  just has sentimental value.
Old Sekonda where called Luch. Think i have a Raketa or a Vostok spring that would work. Does it look like this? https://www.google.com/search?rlz=1C1EKKP_enSE769SE769&biw=1366&bih=667&tbm=isch&sa=1&ei=NtksXJiWFqiOmgXT_p-4Cg&q=luch+++movement&oq=luch+++movement&gs_l=img.3...171612.172940..173434...0.0..0.89.398.5......1....1..gws-wiz-img.......0i7i30j35i39j0i8i7i30j0i5i30.fuAUJHmXJsw#imgrc=fl0ZZa-sYzCqpM:
I have repaired / serviced many  Sekonda's but that movement is new for me. Most Sekonda's as based on Poljot movements. You might have to remove the click spring and then make one from a Shepards hook which you can purchase from Cousins.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
