Hello from the Midwest US
billknechtel
Hello!
Due to my introverted nature, I'm embarrassingly bad at walking into a room and saying "Hello, everybody! Guess who just joined the party?!", but I'll do my best.  Professionally, I'm a computer programmer/web developer and spend a non-trivial amount of time in front of a keyboard making the world a better place, one byte at a time. Personally, I'm a husband, father, photographer, general tinkerer, fountain pen enthusiast, and most recently the co-owner of a little coffee shop & deli. I suppose you could say that at 42 years of age, I still don't know what I want to be when I grow up.
I own a few heirloom watches, and I've always had a fascination with mechanical watches, though I've never really chased that fascination to the point of actively pursuing it as a hobby - until now. Traditionally, I've worn inexpensive quartz watches, and a two years ago was given a nifty smart watch which I enjoyed very thoroughly - until it up and died a couple of months ago. I realized at that point, that even in the best of circumstances, a smart watch  will only last a handful of years, and I'd rather put something mechanical on my wrist.  And because of the way I'm wired - I'd also learn to tear it apart and put it back together in well-working order.
So here I am.  I hope to learn a lot and perhaps develop a few friendships along the way.  While finding adequate time may be a bit of a challenge,  I'm looking forward to the adventure!
Kind Regards,
Bill
Welcome Bill,
Even though I'm a relative noob to this forum myself, I can assure you that you've landed in a great spot. Lots of help, advice and encouragement await you. The cumulative amount of knowledge here is almost beyond belief. They are even tolerant of us quartz fanatics. Sorry to read that your smart watch died. One of my favorite watches is an early 1990's vintage Seiko quartz that still keeps accurate time within +/- 20 seconds/year. It takes all kinds......
Again, welcome to a very friendly forum.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
