  • 0
Stuck Screws?
rduckwor
 Share
Question
Most of my learning efforts are on old, vintage movements; some in great shape, some not so much.  I often find a screw or two that are stuck tight.  Not rusted, just "aged-in-place"  I try typically to put a drop of 9010 on the back side of the screw hole and let them sit and soak.  Sometimes this works well.  I gently heat them by moving my work light close to the movement and allow them to cool which may help move lubricant into the threads.
When this doesn't work, I'm stuck (no pun intended).  Have you a method that also help loosen these old screws up?  If so, please share it.
Thanks,
RMD
2 answers to this question
 Share
  • Similar Content
    • By PaulnKC
      Greetings All,
      Hope that all are doing well - in this crazy COVID world.
      I recently acquired a 1958 Rolex Ref. 6569 with a Cal. 1030 movement. All-in-all very nice and clean for her age - and runs very well.
      The winding pinion and clutch wheel had worn each other out - so I found NOS Rolex parts and replaced those. I though the watch deserved the new parts.
      It appeared to have been serviced in the last 10 years - because everything looked clean and the oil looked good (and present).
      Since the watch seemed to be running well and in good health (other than the winding pinion and clutch wheel) - I didn't do a complete service. I didn't think it was worth the risk.
      However, it seems to me that the watch is harder to wind than I would expect.
      I did do a full service on a 1215 that I bought for my wife (ref. 6694). It needed everything - but an awesome running movement when I was finished.
      The 1215 is of course a manual wind - but similar to the 1030. The 1215 winds lightly and smoothly as one would expect.
      The 1030 is "stiff". I haven't taken the barrel apart - but have just ordered some new mainsprings.
      Is there anything tricky about replacing the auto mainspring in a 1030? Or is more or less like any modern auto?
      Clean the barrel; apply braking grease to wall; fit spring; fit arbor - oil lightly at spring-arbor interface; replace lid?
      Also - I was only able to find a parts-list for this movement. Anyone know where a tech/service sheet (or similar) may be found?
      Thanks in advance for your suggestions.
      -Paul
    • By MechanicMike
      Ok, I need the WRT detectives out there and their help. I've searched and as far as I can tell this symbol or trademark belongs to the Chicago Watch Co. 1895-1903 and made by Elgin. The movement came in an old but intact tin stamped "Elgin Watch Co. I looked up the serial # on PWD.com under 'Chicago' and that's what came up. But, there are a few pics of others and mine looks nothing like any of them nor has this trademark. Anyone recognize this trademark? It's a size 18s with no case. Aaaand I just noticed I didn't provide the serial number. I'll post it here in a bit. Thanks Mike
    • By Nicola00
      Hi, a few days ago i bought a preziosa skin diver, the movement is ok, but there isn't the bezel, where i can find a bezel as in the photos, or a bezel that is compatible?
    • By BrianJW
      Does anyone have any more info on this watch movement?  It's a small women's movement. Measures 21.5mm in diameter. Hour/minutes only. It's not an escapement I've seen in a watch before. The only marks I can find are the AS and 40(?). No name on dial either. Thanks!
    • By TC519
      I recently came across this while digging thru a bag of watches. It looked interesting and all of the Google hits for "Swiss Made Timex" are in reference to the American Documents series. I've got to assume I'm not searching the right keywords. I was hoping somebody might have a little information on the subject. While looking recently, I couldn't locate almost any Swiss Made. Most of the watches I did find were quartz movements. Thanks for any insight the community can muster!
    • I found an answer of yours on this from 2018.  Sounds like I may need to break the crystal to get it out.
    • It is very hard to see that line on my case.  But the ring must be there.  I attached a couple of pics.  One is the top of the case - you can see that the crystal came loose on one side.  I tried to get the same view you did in the other pic.  Not sure if you can see it.  So is it possible to push the ring out from inside? Also what is the best source for a new crystal?  Thanks much for your photo!
    • Welcome to WRT forum.
    • Hello, I have a problem with my ETA2801-2. Initially the watch was running great, but it was skipping while winding. I guess I made a mistake and pulled the train bridge in order to check the mainspring, afterwards I figured that wasn’t necessary. Anyway, after putting everything back together it was running with low amplitude and became impossible to regulate to anything over -120spd. I decided to pull the bridge again, and clean all associated parts in ultrasonic, and re-lubricate. Unfortunately nothing has changed, it still runs with low amplitude - about 230 and there is no way to make it run any faster than -120spd. What could be the reason behind it? Here is how it looks like on a time grapher.
    • Hi, I’m not new to the watch world by any means, but I’m not a pro neither. I like to occasionally work with my watches as a part of watch collecting hobby 🙂
