Citizen 8110A HELP needed (screw location)
Wdc
Gentlemen, I am getting close on the 8110A assembly, but I keep noticing one screw with a shoulder (generally for leaving a little play under the head). I did not notice it on disassembly, noting its position.
Does anyone having experience with this caliber remember where it goes? It is the only screw like this.
@Nucejoe , etc
Thanks in advance,
Will
Edited by Wdc
Hi will,  I thinm the pin you spoke of sticks out of the other side of the mainplate( upper side)  to activate some chrono function. On the lower side dose simultaneously sets the chrono minute wheel  free to zero where it stops. I used to put every part where it suppose to go and not really know which dose what.
I see OH sent a pdf. :geek:
Thanks Joe, the screw in question went to the “Day Dial Driving Wheel” as shown by the pointer below. It was clear when I got to it, the screw head needed to be held off the gear in order for it to rotate. Mystery solved thanks again.
If a moderator sees this, you may want to delete this duplicate post. Not sure how I did it, sorry.
Seems like when I edited it to add the part number it was duplicated by me some how.
Edited by Wdc
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
