Clone rolex!
Yeah I’ve spotted them mate! I was look for a cheap Chinese movement for it now!
DG2813 ... can get one for less than $20 shipped on the bay.
A2836 / A2842 ... about $80 but better quality and easier to service.
Before ordering you must check what movement is already in the watch as the hand's holes size depend on the movement. ... if you swap from a DG2813 to an A2836 or reverse you will have to change the hands.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Beat me to it, you've probably got a cheap low beat 2813 running 21600bph, as has been said these are cheap and easy to find. You need to take the back off to check what you have ok, any dramas post a picture and one of us will be able to id the movement for you.
On 12/24/2018 at 12:21 PM, bosstaki said:
Yeah I know mate! I’m just looking for another movement for it thats all, it’s not mine, it’s my mates!
As some of us already said it definitely is a poor fake
BUT ... because the's always a but ... with some skills and elbow grease one can really improve those cheap watches and make them look really better, though they will never (fortunately) gleam like a gen.
Last year my father-in-law asked me if I could improve one of those old fake watches.
At first I said no but I finally accepted ... just for the challenge
I started from that
and finished with that
I started from that
TYmxZ.jpg&key=3d4923a442943f4e43fcc5845f78bbaa492bface0362ecc7d29dca6df37189eb
TjtAR.jpg&key=a180f83f9f9560ff0bff797ffa99b245f6047befe0417a4d8bd7d00e576d4abe
Nice work there mate!
Thanks [emoji4] that's been a "long journey"
- dismounted and cleaned everything
- removed the crown and tube
- lowered the crown seat
- reworked the crown guards
- reworked the crown (chamfered the base)
- reworked the solid endlinks
- redid the brushed and polished parts on the case
- brushed the bracelet
- polished the crystal
- serviced the movement
- reprinted the datewheel
- changed the dial (still a cheap fake but a better one)
- changed the o-rings and gaskets
- put all parts back together
- tested 5.8 Atm
My father-in-law has been "sort of" surprised when I gave it back to him.
But I sweared I'll never do that again ... funny game but too much time spent for a still so-so result.
I started from that:
and finished with that:
That's pretty impressive.  I've serviced two faux Rolex watches in the past- won't do anymore though.  I've come to the realization that good watches will respond well to service while sketchy ones usually don't.  They just soak up all my time and rarely get the result I'm aiming for.  Sometimes a straight movement swap will work though.
It's a pity used Rolexes appreciate the way they do too- it keeps all those people who want a Rolex, but cannot afford to part with $8 to $10k, in the counterfeit market.  :mellow:
On 1/3/2019 at 1:57 AM, manodeoro said:
Thanks emoji4.png that's been a "long journey"
- tested 5.8 Atm
I know that feeling mate, I done a job on Tissot for a work colleague awhile ago, I’d already done a job on another watch for him and he paid quite well, I took on the tissot and spent hours on it getting it sorted, didn’t need a lot of money to be spent but time well like I said I spent hours on it. Gave it back he was well chuffed etc etc opened his rather full wallet and pulled out £20! I should of gave him a price to start with but didn’t know exactly what was needed. I wasn’t doing it just for the money thinking I was going to make a wedge, but it was abit if shock when that was all I got for the amount of work done. But hey ho lessons learnt.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
