Hello From Reading
Hello all,
Just joined wanted to say hello to everyone and introduce myself.
I live in Reading Berkshire and am well on the way to being 57 years old.
I am a complete novice having just started taking watches apart in the last week or so but watching the Watch Repair Guy videos on You Tube has whetted my appetite.
I currently own 2 pocket watches, inherited from my grandad,  both not working and both probably only worth just a few pounds each (if that).
Unfortunately I have been unable to identify the manufacturer of either piece but I think they are both Swiss made, one in silver (no hallmark just marked "Fine Silver") the other could be gold plate.
The silver piece has a hairspring problem in that the spring has detached itself from the stud, resulting in a some deformity, plus it seems to have a broken case spring.
The gold coloured one also has a broken spring but it looks like a hairspring so I'm hopeful I can find one in a job lot from e-bay :-)
Well, I'm looking forward to learning all I can and maybe some day I'll be able to get the hairspring sorted out .
Bye for now
Welcome to the forum Ewan, there is a lot of knowledgeable folk here from all aver the world willing to help with all sorts of issues.
It would be interesting to see photos of your watches, I'm sure someone will give you some information on them.
Thanks for posting the quality pictures Ewan. That's a good looking movement in the gold watch going by the screwed in jewel settings. I'm sure some of the pocket watch specialist may shed some light on what you have here. Dare I ask, for pictures of the dials to see what they look like?
Sure guys - I'll be off work in a few hours and I'll take a few more shots then for posting later this evening.
I have a question regarding the hairspring balance wheel on the silver watch as it's smooth - there are no balance screws and the hairspring stud seems to be just a push in fit - is this because its a cheap movement perhaps ?
Anyway, I'll post pictures later showing what I mean.
OK - here's a bit more info and the updated pics as promised.
The silver watch case is about 37mm diameter (outside edge to edge) - the dial is 33mm diameter. The case is marked "Fine Silver" with what looks like a crown mark above the words and the number 101186 stamped on the back case and cuvette (is that what the cover over the movement is called). The movement uses a separate key  - the original is lost. The hands are removed in the picture of the dial and unfortunately the glass dropped out while I was removing the movement from the case.
The gold case is larger with an edge to edge diameter of 50mm - the movement is 42mm diameter. The case is marked "Geneva watch case co"; "case warranty for 10 years " & "TEMERAIRE" with a number of 887116.
Pictures below - would be great if anyone can tell me a little bit about them.
Let me know if you'd like any more pics :)
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
    • Hi as an addition a pertaining to the assembly of a 6319B  which will be handy for those working on this caliber Polly's 6139 guide.pdf 6139A.pdf 6139B.pdf
    • Casio MDV106G-1AV Gold DURO200 I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable. Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them. Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀 The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
