This Is Me
bjd1020
I love watches.  I had an oris TT1 for almost 15 years.  When the crown wouldn't seat properly I went outside one blistering morning and ended up with condensation in the watch.  I was quoted 2k to fix.  As an engineer when I came across the rusty valjoux video I figured I could accomplish this myself.  Im on my 4th attempt and 4th escape wheel and learning a ton everyday.  I have invested a toooooon as well in money.  LUBES>>>>  Lord have mercy, the lubes are worth more than gold.   Along the way I have participated in several forums.....only to have been met with discouragement and belittlement....until now. Thank you.
Hi bjd, welcome to the asylum, this forum is "the bizz," loads of really knowledgeable people who are happy to help you. They have helped me over the line many times and I have never been made to feel stupid, even if some of my questions have been!:D here there are many people of all abilities, but United in our shared love of watches.
Welcome pardner,
The most belittling comment you're likely to receive on this forum is "have you thought about trying this, mate"? This is a welcoming, encouraging bunch of watch and clock fanatics, many of whom possess some real talent. They seem capable of both abiding and teaching those of us without much ability or talent. Who could ask for more?
Its good to know. There are a couple of guys who have been helpful over there after I stayed persistent. Trust me im all about a little initiation and hazing as a newby. I have the utmost respect for the guys who are experts. I also have a great deal of respect for the body of work. If anyones is interested in reading the drama here it is. If its not allowed please delete.
https://forums.watchuseek.com/forum.php#/topics/4831077?page=7
Im guessing that some of the participants may actually be members here as well.
Sent from my SM-G950U using Tapatalk
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
