Regulating a 7750 with Etachron
Giuseppe
I'm having some unexpected behaviour from a eta 7750 that I'm trying to regulate after servicing.
I went through service procedure using correct lubricants.
Everything went fine. Actually I have some doubt on lubrication of incabloc wich I'm not sure I did correctly since I'm afraid that too much oil was placed in one of the two stones.
The fact is that when I finished I wasn't brave enough to clean and lubricate it again ... shame on me but I felt that task to be very very difficult.
Anyway after reassembling the watch I had it at my wrist for a week and it showed a great consistency at -10 sec a day.
It'a stop grade movement and resting at night in DU, DD 9UP and 3UP positions always showed something between -14 -6
I was very happy with that result and I thought that a little regulation would have brought it to a very fine time keeping.
Then I reopened the caseback and slightly moved etachron arm, that was resting in a nearly neutral position, in the + direction.
Nothing happened (measuring with timegrapher open source app)
Did it again, another slight push.
Nothing
? ok I must have gone the wrong direction, then pushed all the way toward   -
Nothing happened.
Ok this is annoying, all the way toward +
nothing
here I am,
what I'm I missing?
How come moving the regulator arm from - to + does not make any variation?
I'm lost
  • Similar Content
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
